Bradmph
Pulling my weight
Have you setup the your mic system for an external outside speaker as well? I am thinking of installing an external speaker, but I am wondering if the audio out (yellow) plug is just for listening to the connected mic on the camera.Sure would. I have set it up that way. This is what I've learned:
Need at least 1A - 12V power supply. When using this 5A PS from Ebay;
12V 5A 60W Power Supply AC to DC Adapter for 5050 3528 Flexible LED Strip Light | eBay
I was getting a ground loop from the mic, no matter if it was connected to the 5231 or the SD59. Switching to a 2 prong -- 1A power supply removed the ground loop, and these mics are super sensitive. Reduced the sensitivity to 30 from the default 50.
SD
My camera and mic right now are set up on BI, but I don't have power supply connected. There is a round green icon showing in R corner in BI on this camera's display, but no sound can be heard from headphones. SO I am imagining that the power supply will change all this to enable listening with headphones or system PC speakers correct?
I ordered
