I totally missed this in the link I included in my post #1457.Found this on the Blue Iris forums, haven't tried it yet Blue Iris Tools stopped updating - Blue Iris
There is never not a good time to quote UHF.
Just my luck, it looks like BI's web server went belly up, and the forum is no longer available. Do you recall what the fix was?Found this on the Blue Iris forums, haven't tried it yet Blue Iris Tools stopped updating - Blue Iris
What web server are you saying has gone belly up, if you mean the BI user Forum; it is working fine for me, are you sure that you have the correct URL see the following Blue Iris by Perspective Software LLC | User Forum address for the updated user forum URLJust my luck, it looks like BI's web server went belly up, and the forum is no longer available. Do you recall what the fix was?
Go here => Blue Iris - Index pageJust my luck, it looks like BI's web server went belly up, and the forum is no longer available. Do you recall what the fix was?
True, but they were having such a huge burden dealing with spam and bots that this was implemented as a workaround. Keeping out the riffraff as best as possible....I'm not sure it's completely obvious, most forums like this out there wouldn't require you to login to just see content. To post, yes, that would usually require to be registered
Yes, you be you because you're better at it than anyone.Understood, but I wouldn't criticize someone else for not realizing that you have to login to see the forum, but that's just me
BTW....was someone being criticized in this thread? I must have missed it.
No, not there but...it seems you're getting worked up over something that's not there....I certainly can be mistaken.Or is there something else you found funny there?
Cool man.No, not there but...it seems you're getting worked up over something that's not there....I certainly can be mistaken.
I did not mean to incite you or anyone else or criticize anyone here.
I consider myself articulate enough to be perfectly clear and leave no doubt who and what I'm referring to if I am criticizing someone, their method, their product or their proposal.
As a general rule, and I'm not pointing fingers here, but a forum can be a difficult medium to traverse if one is thin-skinned, overly sensitive or somewhat paranoid (thinking everything is directed at them).
Hey guys in reading the fix for the BIT weather updates on the posted on the openthings.freshdesk site mentions this:
If you don’t own a physical PWS, the generated PWS will not provide valid data. Do NOT use this PWS for weather adjustments.
Several users noted this fix as working. Are they getting physical devices, or am I just reading into that wrong? Thanks guys.
I followed the directions to generate an API key without owning a PWS device. I used the new API key in BIT for my weather overlay and thought I was in the clear. Worked fine on my BI system and my dad's BI system to display the weather overlay. But I noticed that in the middle of the day it'll stop working for like 6 hours. The 6 hours stoppage happens everyday but not always at the same time (usually around 12pm or 1pm ET). Not sure what's causing as I clearly have internet and I can see the station ID is actively reporting current weather. Maybe I'm pissing it off by updating every minute. LOLHey guys in reading the fix for the BIT weather updates on the posted on the openthings.freshdesk site mentions this:
In BIT I see the following error message below when it stops working for 6 hours:
Instead of seeing this:
I now see this:
See the clip log below. It shows it's working then it stops working then it starts working again.
