shelestoff
source is trust - official overseas CIS support specialist showed a snapshot from GDP systemWhat is your source?
what are you doesnt understood?
i was mean right this new 4.0 version.Nothing is misunderstood, I was looking for clarification. You said “that firmware is closed.” I thought you might have been talking about another build.
Anyone have this problem?
I also have an 5216 which doesn't have an issue, but here my thoughts:
- are you sure it ain't the hard drives clicking (unplug them in shutdown mode)?
- are you sure the firmware upgrade went 100% correct? I remember @EMPIRETECANDY stating once that downgrade was not possible!
I powered it up brand new. There is no hard drive attached. I attached and detached a hard drive. Made no difference. Downgrading the firmware makes the problem go away.
Yes, pretty sure the firmware update went fine. I already upgraded and downgraded 3 times. Same problem. Going back to v3.216 always have no problem. The NVR works fine. All the menus and options works fine. I even loaded up 6 cameras automatically detected by IP scan.
Here's the clicking sound.
Did you make a factory default after flashing and reboot?
Can you try to hear, where is sound: mainboard or power supply?
I thought you cannot downgrade 4.0? Can I downgrade to previous version as I too am having issues with the 4.0.
Using IE, Chrome or Firefox when accessing Management - Camera- Encode - Please Wait=message appears and never goes away and hangs the browser. Cannot get past this point using Web Browsers.
I just send the video to the dahua guy, let's see.
