6.0.3.6 New Logfile Entries
yes, I see entries for both defender and Bitdefender. No big deal, just clear the log entry and the yellow icon goes away, but best if he can fix it...comes back each update. (I did reboot after 6.0.4.1...still shows on every update)
I have been looking at why one of my systems thinks it is running Windows Defender and the other does not as far as BI is concerned, based upon some info I got from Ken I am seeing that one is running "MsMpEng.exe" and the other is not. I used Process Explorer from Microsoft to be able to see what process's are running, since Ken is also looking at the running processes to determine which AV is operating. "MsMpEng.exe" has the descrip[tion listed as "Antimalware Service Executable", I am currently still unable to determine why it runs on the one system, when it should not be!
If you want to check your system to see if MsMpEng.exe is running you can download Process Explorer here Process Explorer - Sysinternals
