aristobrat
- Dec 5, 2016
- 2,979
- 3,180
Regarding Blue Iris and Dahau IVS signaling, ... Blue Iris supports Hikivison's "Smart Event" signaling (which is essentially the same thing), so its not out of the question that the author would add it for Dahua, if someone provided him documentation that explained how Dahua does it. The BI author is great, new features and tweaks are added every few weeks. When I moved from my Dahua NVR to Blue Iris a few months ago, H.265 from Dahua Starlights didn't work properly. A few of us here emailed support and the author had it fixed within a week.Since it doesn't appear that Blue Iris supports Dahua IVS signalling (which is a bit of a shame since advanced IVS features add the extra cost borne by the higher end cameras), I'm also curious how the BI equivalent options compare to the Dahua in-camera IVS.
Regarding Blue Iris Motion Detection vs. Dahua's IVS:
My motion detection needs are simple. For all of my cameras, I have a rectangle area that I need to know when someone moves into, out of, or within.
Dahua IVS (Intrusion, with "Crosses" and "Appears" enabled) handled it so perfectly (99% no false positives) that knowing I'd lose this feature going to Blue Iris, I really really really really resisted moving to Blue Iris. Had there not have been a Dahua NVR firmware bug back then that forced my hand, it'd have never gone to BI.
With Blue Iris, I've got the same rectangle drawn for each camera. For the life of me, I can't tune out the false positives that I get on sunny days when the shadows from poofy white clouds roll across the cameras view. It's the kind of shadow that looks like the horizontal thick line that used to scroll down old TVs when they weren't tuned great.
Per @fendermans point, BI has so many more Motion Detection options where you can put several boxes on your screen and make rules that say "only alert when someone goes from this specific box to this specific box" (and it can get even more complex than that), but when you've got a shadow that rolls across everything that comes from the NE one day, and from the SW next week, and the complete opposite ways on other days, it's like WTF. What rule can you create for that scenario that doesn't also mask legitimate motion traveling those directions?
Blue Iris does allow you to change the contrast ratio, so it won't trigger when the shadow isn't very dark, but that's a balance ... lower the contrast setting too much and someone with dark clothes walking against your dark green grass won't trigger. Blue Iris also lets you set the "maximum size" of things (and not to trigger if something is too big) but when these shadows are only take up 10% of the camera at any one time, but they roll down the field of view, so that feature doesn't help out a lot either.
Even with all of that, I hands down love Blue Iris vs the Dahua NVR. BI's iOS app makes it so easy to check in anytime and see the clips of motion that were recorded. And they play back very quickly over LTE on my smartphone. With the Dahua iOS app, playback over LTE was iffy, at best. And heaven help you if you have scrub forward or backwards, it pretty much never did for me. Finding the clips on the Dahua app was a PITA. I always had to specify a time window (say today, from 1pm to 3pm), and then it'd take a literal minute to search for them, and all it would show me would be markers on a timeline. With Blue Iris, I login, select my camera view, an each camera has a notification in the top right that shows the number of new alerts. When I tap on that, it shows me a picture of each alert, in a chronological list. If I want to see the video, I tap, and it starts playing. Love it. Check in on my house a few times throughout the day. With Dahau, I'd get so frustrated using the iOS app from work that I'd have to come home and sit down at a computer to see what happened during the day.
