Xprotect Triggering SMD PTZ with AutoTracking
MR2
Joined
Jan 25, 2016
Messages
97
Reaction score
40
Anyone have a Dahua SMD PTZ in Milestone and triggering presents which allow Autotracking?
when I create them on the camera they show when imported to Milestone however I've yet to see the the Auto Tracking side of things kick off?
wittaj
Joined
Apr 28, 2019
Messages
25,681
Reaction score
50,136
Location
USA
Dahua PTZs only autotrack with Smart Plan and IVS.
Unless you are saying Milestone has the capability to do autotracking and direct the PTZ where to go?
MR2
Joined
Jan 25, 2016
Messages
97
Reaction score
40
well, it's odd, in the camera you add the Smart plan to a preset? it seems that Milestone then calls the preset, does this then trigger the smart plan for that preset?
wittaj
Joined
Apr 28, 2019
Messages
25,681
Reaction score
50,136
Location
USA
Yes, you have to setup the Smart plan and IVS rule for each preset that you want autotracking for.
So I have 14 presets with autotracking for each one.
Then when Milestone calls the preset of the PTZ, the camera then takes over and does the tracking.
Reactions: MR2
MR2
Joined
Jan 25, 2016
Messages
97
Reaction score
40
Sweet, thankyou so it should work, probably something else I've missed then
Top
