Mike A.
- May 6, 2017
- 4,209
- 7,096
Tried. Just makes it worse. lol Exposure compensation really seems to do nothing at all. Gain does obviously but lowering it just makes the dark areas larger and darker with not much effect on the center. Understand very hard to make suggestions without seeing and trying things real time. But not worth bothering with now. I'm still just playing to learn the cam. Which has been useful.
Based on what I've seen I think that I'm going to end up moving it to another location so that I'm shooting more out and over a wider area vs down which will help with the hot spot effect if I do want to use the illuminators. More likely I'll just use external lighting but need to change what I have now. It's wayyyy too bright. Even a 5442 that I have looking at the same area switches to color with that on. Don't want it that bright out there all the time. Need something that I can dim way down as you did and control remotely.
