Parley
I will say this Wildcat_1, you do look thinner with the Dahua 5849-A180 / Color4K-B180.
I need bullet with 2.8 mmThanks for @Wildcat_1 great job, let's wait the nightvideo next week. We will get the stocks at early Dec, so will make some sales on these new models later. Both turret and bullet.
I will say this Wildcat_1, you do look thinner with the Dahua 5849-A180 / Color4K-B180.![]()
Thanks for the pics. I have to say there's quite a bit more distortion than I was expecting.
I've placed an order for 2 of the turrets with Andy. I intend on using them to replace a couple of existing cameras where they ought to fill in some current blind spots, and then use one of the cameras I take down to replace an old 2mp Hikvision camera, and the other to add some additional coverage at the front of the house.
I'm curious to see what the nighttime images look like. I'm wondering how one of the 180's would work as an overview camera mounted on a pole about 15' from the private road that runs in front of our house. It would have an unobstructed view for about 100 yds in each direction on the only road access in and out of our small development.
Yes these type of cams are great as overviews and even better for utilization in overwatch/spotter setups where you use this cam along with PTZ activation to call a PTZ in your deployment to a given preset. Wider the coverage of this cam, more options to call to differing presets within the same wide FOV more precisely.Thanks for the pics. I have to say there's quite a bit more distortion than I was expecting.
Hello Wildcat_1, you have an PM.Yes these type of cams are great as overviews and even better for utilization in overwatch/spotter setups where you use this cam along with PTZ activation to call a PTZ in your deployment to a given preset. Wider the coverage of this cam, more options to call to differing presets within the same wide FOV more precisely.
With the red and blue it starts to look like a police carDahua combines this product with TiOC.
I'm definitely not an advocate for the TIOC series at all, so hopefully they will leave the A180 aloneHopefully they are not trying to do too much with this camera and turn it into the 8MP IPC-HDW3849H-AS-PV TIOC that underperforms...
If they keep the camera with good specs, blue flashing lights and a siren is excellent to trigger when the camera is being tampered with. Particularly because these cameras cannot be mounted very high.Hopefully they are not trying to do too much with this camera and turn it into the 8MP IPC-HDW3849H-AS-PV TIOC that underperforms...
Do you have a TIOC? I do and the red and blue flashing lights are a gimmick and can only be see if the person is looking directly at the camera! I was hoping it would look like a police car lights reflecting off of everything and it does squat.
And we have enough evidence here that lights coming on are not a deterrent. Audio stands a much better chance.
This would be a nice capability. But personally never figured out how to set up spotter cam’s for my PTZYes these type of cams are great as overviews and even better for utilization in overwatch/spotter setups where you use this cam along with PTZ activation to call a PTZ in your deployment to a given preset. Wider the coverage of this cam, more options to call to differing presets within the same wide FOV more precisely.
I’m running BI. Some here tried to help several months ago. I never could get it to work proper.It’s pretty easy.
I can help you if you’re running a Dahua NVR, others here can if you are running BI
