bigredfish
So last try to make this D2 3.6mm work somewhere. Im afraid with it being the first generation with mismatched sensors, its a dud.
I've hit the Calibration button so many times its starting to get a mark
Any of you experienced old timers need a project cam to play with? Its just gonna collect dust here
Compared to the new VF 5442ZHE
OK, here is my take:
I have a new Andy-T5442TM-LED-S2 cam with 3.6mm and F=1.0 here, which is also rather blurry. Mine is a turret, yours is probably a bullet version. Mine should be focused from 2.6m onward, yours should work from 2m. Mine is less clear than the 2.8mm model from the same series, despite stronger magnification. In other words, useless.
I doubt the problem is from stitching. You could check: Turn your cam into a "pirate cam" by covering the IR lens. Then you can see just the color picture. I expect it to be still as blurry.
To evaluate the optics, use bright daylight, high bandwidth and ZERO sharpening.
I am not sure if the lens assembly of the 3.6mm version is poor or just poorly focused. But at the spec distance, it isn't well focused. Not even at 9 meters.
On the other hand, your comparison is not fair either, as your varifocal has a variable focus.
The only charm of the D2 would be to have great low light performance and IR to fall back on if it gets too low. If you can rule out that problem, then my lens should be just a good. But hey, it is blurry too.
I agree. I have a 5442 in place right across from it and it works great. This one is more of a toy now. It's unique and works but there's better options that are the same price or cheaper. It doesn't really fit in anywhere. It still lacks the overall sharpness the 5442 which is the most disappointing part.Frankly even if the new version with matching sensors is "better and the blur is almost gone" I dont see enough value in features to replace an otherwise superior 5442 or 4K-X
I messed with that when I got it. It was about the same level of sharpness. So while V2 has better stitching, the camera just isn't focused well (like the V1). I'm not placing blame on Andy but I'll say this camera is a very easy pass and not worth the money (the turret version specifically).OK, here is my take:
Mine is identical to yours, 3.6mm turret.
I can just as easily compare it side by side with a 3.6mm 5442 fixed turret. I doubt we'll see any significant differnce as you'll note the VF bullet above it is almost identical in FOV as I have it focused, and in theory ANY zoom past the base 2.7min on the VF will produce Less light/higher FStop
Then we likely have the same full color part.Mine is identical to yours, 3.6mm turret.
Yes, you could. But that F=1.6 turret has less lense opening and hence should be better focused. Specs say 1.9m. So yes, the picture quality should improve at the price of light.I can just as easily compare it side by side with a 3.6mm 5442 fixed turret.
Perhaps you misread? I don't have a dual lens cam. I have the single lens full color cam that is also used in the dual lens cam.I messed with that when I got it. It was about the same level of sharpness. So while V2 has better stitching, the camera just isn't focused well (like the V1). I'm not placing blame on Andy but I'll say this camera is a very easy pass and not worth the money (the turret version specifically).
