Wooded campground -- 3 cam zones connected via bridges to Starlink
Apr 21, 2026
4
United States
Hi all. Need some guidance here please. I've been charged with setting up 3 surveillance zones in a heavily wooded campground --- a "home" zone at the camp store/office, and 2 remote zones monitoring several buildings 500 ft away and 700 feet away respectively. The remotes will have 5 and 6 indoor & outdoor cameras, most PoE/some wifi+solar in each zone. Hoping to utilize an NVR to collect each remote zone's feeds and then ALSO to also transmit each of those 2 remote zone feeds back to the office zone using bridges.
Because of trees, I'll have to relay the bridge zones but 2 of the relay points won't have access to 120v power, nor will the tree canopies allow for a solar panel/battery/inverter to provide power. Any ideas from you fine folks?
The best way I can describe my proposed layout is as follows :
Bridge jump #1 : Store to Pole #1 (~60 yards clear line of sight but no power)
Bridge jump #2 : Pole #1 to Pole #2 (~80 yards clear LOS, but no power)
Bridge jump #3 : Pole #2 to Remote Zone 2 (~50 yards clear LOS, has power available)
Bridge jump #4 : Pole #2 to Remote Zone 3 (~80 yards clear LOS, has power available)
Am I able to "push" power from the store to pole #1 using a PoE injector?
Am I able to "push" power from either (or both) remote zone buildings to pole #2 using a PoE injector?
Any other special hardware needed to achieve this other than outdoor PoE switches on each jump end? Can I use ONE switch on pole # 2 to power and xfer signals from all three jumps connected to that pole? Wanting to utilize our store's Starlink Gen 3 for all wifi coverage too, so not sure on what special hardware needed (I've seen a Starlink Gen 3 Ethernet Adapter being needed?). Sorry, so many questions and can't quite find an answer anywhere online for my unique situation.
Final question : am I able to gather the many camera feeds into ONE NVR at the store (store will have 7 cams, zone 2 = 5 cams, zone 3 = 6 cams), or will I be better off using an NVR at each zone? Boss wants to be able to pull up any camera on his phone so was hoping to gather ALL feeds into one place for him to access. He'd prefer Reolink hardware so have been building a shopping list of cams and NVRs to look at. Any assistance GREATLY appreciated.
Cheers all, Mike
How about a simple, hand-drawn but clear sketch of the proposed layout that reflects the above? Speaking for myself, it would clarify things a lot.:cool:
Sorry for that. Here's a drawing that (hopefully) helps show the layout. Forgive me if I'm not using the correct nomenclature ---- I think each connection between a pair of bridge antennae is called a jump, but I might be wrong.
Starting at the bottom left is the camp office, with the start of jump 1 marked "A". Moving to the right is the end of jump 1 / start of jump 2 marked "B". Head up the road halfway to a power pole which would be the end of jump 2, marked "C". From that point, I anticipate bridges heading in two different directions ..... pole "C" to the building on the right edge marked "D" being one jump, Pole "C" heading towards the buildings in the upper left marked "E".
I have no power readily available at points "B" and "C" and the tree canopies would unfortunately make a solar panel-sourced power supply impossible. Points "A", "D" and "E" all have 120v AC power available.
Groups or clusters of cameras would be at the following points : A (camp store), D (remote bathhouse) and E (laundry/pool etc). Each of these three locations will likely have their own NVR if I can't get ALL individual camera feeds to the home base at building A (camp store) in one large switch/NVR setup. Grand total of around 18 cameras (A=7 cams, D=5 cams, E=6 cams).
Hopefully this makes more sense now. Open to ANY and ALL ideas or thoughts or other options.
Cheers to all. Mike
Regarding your question to run POE power to poles B and C, are those 2 poles privately owned (by the campground) or by the local power company? If they are installed, owned and maintained by the power utility co. then "no", you cannot and should not run any kind or cables to them and between them.
It would require written permission from them and there would be specific requirements and specifications, a complicated process, IMO. :confused:
