Yes highly recommend the PFA 122 (3 hole) HERE
and PFA 121 (4 hole) HERE as they feature interchangeable faceplates that make it easy to mount the cam to the plate on the ground then quickly switch out at location. Always have a number of these on hand, work great on the 3 hole Dahua & Hikvision cams
Just to confirm, the 5849 (Color4K-X) 3 hole would work fine with the 3 hole PFA122?
Also, can the junction box be mounted horizontally? That was always my plan in the spot I have, but I can alter that location if mounting it horizontally would invite water ingress etc.
[/QUOTE]
YES Color4K does use 3 hole PFA122 without issue (have 1 mounted that way now). YES you can mount the 121/122 horizontally if you wish
