Hand planes are mentally therapeutic !You're more ambitious than I am. I'd use a power plane and a sander!
Make sure you have the motion zone cleared out, in the camera gui, making changes in BI to a cam tends to re-enable the motion detection on the cams.Got birdhouse and SD4 ptz set with new vertical tripwires and intrusion boxes. The dang 5442 still triggers on cats & dogs. I hope that SD3.0 comes out soon. I have to upgrade the ptz firmware that is, I believe, available cause it sets off alerts on motion triggers when I don't have motion checked, only IVS.
Gots invigorated to get flattening my Roubo workbench table top with hand planes last night. 4 hours but result is good. Now for the 2nd flat top.
I have a combo of things that need to get done at same time. Camera security and workbench so I have room in my garage.
dang it... my Windows Remote Desktop is unable to connect to my Blue Iris machine. I think I'll be swapping over to Chrome Remote Desktop as that seems to work really easily although I believe it relies on the cloud instead of local.Make sure you have the motion zone cleared out, in the camera gui, making changes in BI to a cam tends to re-enable the motion detection on the cams.
You’re supposed to only put planes down on their side. At school (a vast number of years ago) the woodwork teacher used the cane if we left them like that. Didn’t take me long to learn...Hand planes are mentally therapeutic !
Some people have had an issue where if they make a change to the camera in BI that it turns motion on in the camera. Make all changes in BI and then go back into the camera using Internet Explorer and see if that holds then.
Perform #2, and you'll not have to worry about it any longer. No need to complicate the process. If you clear zone area it won't matter if the Motion get's enabled again.Hey @looney2ns - is this why I might be having problems!? Questions:
1. I'm trying to use Dahua IVS only, so I disable the Motion option. I'll come back a day later and it is Enabled again! So the IVS Triggers won't matter, since it's catching ALL motion?
2. Do I need to clear the Zone Area as you've shown in your picture? AND click Disable Motion?
3. Do I have to check the camera GUIs every time I change a camera setting in Blue Iris?
