Why more than 2 users won't see live stream?
vanni93
Joined
Apr 18, 2019
Messages
10
Reaction score
Location
Italy
I need to show 3 ip cam Hikvision over the LAN of my building. After many issues I finally found out how to do so, the problem is that if more than 2 users open the website of the 3 cameras, the last user that connects to the url won't see anything just 3 black boxes instead of 3 live streams.
This is the code I used
<object classid="clsid:9BE31822-FDAD- 461BAD51BE1D1C159921"codebase="http://downloads.videolan.org/pub/videolan/vlc/latest/win32/axvlc.cab" id="vlc" events="True" width="500" height="480"> <param name="Src" value="rtsp://admin:psw@ip"/> <param name="ShowDisplay" value="True"/> <param name="AutoLoop" value="False"/>
<embed id="vlcEmb" type="application/x-google-vlc-plugin" version="VideoLAN.VLCPlugin.2" autoplay="yes" loop="no" target=" rtsp://admin:psw@ip " width="500" height="480"/> </object>
Thank you for your precious help. Have a nice day
TonyR
Joined
Jul 15, 2014
Messages
17,042
Reaction score
39,634
Location
Alabama
Sorry I cannot offer some insight into your problem but would like to pass this on. If you post your code inside the CODE tags you won't get the smiley face icons. Select the + sign at the top of your post window and then </> Code and paste in your code. It will appear as below:
Code:
 <embed id="vlcEmb" type="application/x-google-vlc-plugin" version="VideoLAN.VLCPlugin.2" autoplay="yes" loop="no" target=" rtsp://admin:psw@ip" width="500" height="480"/> </object>
SouthernYankee
Joined
Feb 15, 2018
Messages
5,170
Reaction score
5,321
Location
Houston Tx
You are overloading the cameras ability to process the request. The cameras job is to process video not web requests. Get a high quality NVR or a PC running a VMS(bi). Run you request from there.
TonyR
Joined
Jul 15, 2014
Messages
17,042
Reaction score
39,634
Location
Alabama
+1^^.
An appropriate PC with Blue Iris would allow each user to be controlled uniquely: by schedule, by time limit, by camera(s) viewed, even limit bandwidth. Users can use their browser on their PC, tablet or smartphone to access BI's built-in web server, over the LAN or remotely.
fenderman
Staff member
Joined
Mar 9, 2014
Messages
36,908
Reaction score
21,295
Generally 3 users should be ok, do you have a very high bitrate? Also if using certain low end models like some china region cameras the processor may not be sufficient.
Look into the multicast function on the camera.
vanni93
Joined
Apr 18, 2019
Messages
10
Reaction score
Location
Italy
You are overloading the cameras ability to process the request. The cameras job is to process video not web requests. Get a high quality NVR or a PC running a VNC (bi). Run you request from there.
I could also use a pc as a server.
Could you please tell me how to configure e what VNC to use?
free would be better
vanni93
Joined
Apr 18, 2019
Messages
10
Reaction score
Location
Italy
maybe I could try with the ivms 4200 stream media server from hikvision?
But I don't know how to configure it and how to allow stream over the LAN
TonyR
Joined
Jul 15, 2014
Messages
17,042
Reaction score
39,634
Location
Alabama
I think a post earlier by another forum member contained a typo and he meant VMS (Video Management System), not VNC (Virtual Network Computing).
I highly recommend Blue Iris...It's very inexpensive, highly configurable and this forum has MANY members that can assist. My best suggestion regarding a server PC for it would be for you to read the Wiki above, and pay special attention to the section entitled "Choosing Hardware for Blue Iris."
vanni93
Joined
Apr 18, 2019
Messages
10
Reaction score
Location
Italy
I have configured the IMVS4200 Streaming Media Server of Hikvision, but now what?
What's the next step in order to allow all my users to see live stream?
I need like a url o something?
Top
