fenderman
Staff member
- Mar 9, 2014
- 36,891
- 21,417
When I drink alone I prefer to be by myself. No wifi. Nothing. Just me and the toilet.There is a solution, you know. Look into a "leaky feeder".
Hmmm. That sounds bad now that I read it.![]()
Way off, my work pants are black.
Cheap DVR/NVR 4x camera kits are as cheap as $149.99 when on sale/clearance. It's not that Dahua's are too expensive. But if someone doesn't have anything to compare too as far as quality and only price, and I only have Dahua's, they would seem to be expensive.
Thanks for the replies.
Why are the Dahua Starlight IP cameras so recommended when a single camera costs almost as much as a cheap all-in-one DVR setup? I'd like to hear every reason there is. I've already bought some myself, I have 2x 2231 and 1x 5231. They're great quality cameras, and I come from a custom PC building hobby where I value quality stuff. But if I had to convince someone else to buy these cameras, or at least defend my purchases, and particularly from some guy named Andy in Hong Kong, what would I tell them?
I'd like to have a buck every time a parent has asked me advice on which laptop to buy for their soon-to-be-off-to-college son or daughter.Yup, at $99 on clearance computer just will not perform as well as a better system for that purpose.
There are plenty situations where you're better off spending your money smarter not just spending more of it.More often than not, that old adage "You get what you pay for" is very true when it comes to IP cams, PC's, laptops, etc.....most tech devices.
Turns out, it's a 1.6GHz Celeron with 2GB of RAM.......duh.
I quote them around $600 + or - for one that I could live with and they call me a few months later with the one they got for $300, saying the young student is complaining "....it's soooo s-l-o-w." Turns out, it's a 1.6GHz Celeron with 2GB of RAM.......duh.
You definitely are getting yourself into an unpaid tech support commitment whenever you recommend or obtain gear for a friend or relative. Sometimes it's worth it. Sometimes not so much.For a close friend or relative, you could make the purchase from Andy yourself and resell the cameras. They down side is they're more likely to expect support![]()
Yeah, been there done that. You'd think that when a relative requires extensive tech support that they'd at least send you $20 at Christmas or on your birthday. Nope. Sometimes the best solution is just to send them a link to an article, tutorial, or manual and tell them you're too busy.You definitely are getting yourself into an unpaid tech support commitment whenever you recommend or obtain gear for a friend or relative. Sometimes it's worth it. Sometimes not so much.![]()
Boy, have I heard this song before...... You even point out the pitfalls and problems they should be careful of.
.....What do they do? Ignore all of your advice and then ask for help resolving the disaster they created.![]()
The worst are the people who really need some tech advice. Out of pity you offer unsolicited advice about how they should go about doing or upgrading something and that it can be relatively easy/inexpensive. You even point out the pitfalls and problems they should be careful of.
What is the model of your CAM2?
I quit trying to explain it. I just show them these 3 images of the same dirtbag and they usually get it pretty quick:
View attachment 37889 View attachment 37890 View attachment 37892
