mat200
- Jan 17, 2017
- 19,442
- 32,482
@GaryTX87
You've got a tight budget, and I know you want to get the most value out of it.
Remember cabling takes times, and thus it is best if you invest in better quality cables ( with solid copper wire ) - and most of us here would rather use cat6/5e as it is a better option for future considerations.
Sometimes there are affordable kits from LaView onsale - the LaView kits I looked at are hikvision OEM for their IP PoE kits, and while LaView's customer service leaves some more to be desired their kits are at least better than many other options out there.
I would look at Slickdeals and search on LaView, you may find some kits which work for you listed on sale there.
You can also look at the LaView website ( laviewsecurity.com iirc ) and note they will have a % off deal typically going on as well as periodic deals.
Naturally the longer time you give for a deal to come up on a decent kit, the better value you will find.
The most affordable kit I would buy so far has gone on sale from Newegg for ~$280 w/o a HDD. ( 4x cameras IP PoE ) Kits which cost less I would be cautious about purchasing them.
Also remember, you'll have some compromises with affordable kits.
