area651
Getting comfortable
They will work fine, and your video quality will not be affected. If you don't want to "drill" larger holes, cut off the RJ45 and re-terminate after fishing the cable.
Cat5e is fine. I have over 6000+ feet of this under my belt, and countless cameras installed all operating as intended.
1000FT CAT6 CAT5E UTP Solid Network Ethernet Cable Pure Copper CAT5 RJ45 Bulk US | eBay
This guy is in NJ and ships quick. That cable is solid 24AWG copper and is $58 shipped to your door. He has the same Cat6 (in 23AWG) that Monoprice sells for $50+ more (when adding shipping) for $68. That 4 way separator in the Cat6 is harder to work with when fishing or bending the cable. Don't get me wrong, it's nice stuff, and I have a 1000 feet of it on hand, but it really isn't necessary and Monoprice is Mono-over-priced.
Cable is the cheapest part of any security camera solution, but here's the thing. Most cams, including 4K cams, run at 100 Base-T anyway. A properly terminated Cat5e can do better than 350 MHz anyway, but even that is overkill for 100 Base-T. If you don't properly terminate Cat6, it won't test out to 550 MHz either. You have to use the proper RJ45 connectors and keep the untwisted portion as short as possible (<3/8"). I like these "3 piece suits" as they keep the untwisted portion as short as possible, and you can double check your cable order before crimping. They work very well with 24AWG Cat5e as well.
https://www.amazon.com/gp/product/B01K9Z3ZWA/ref=oh_aui_detailpage_o03_s00?ie=UTF8&psc=1
Here are the tools of the trade, and the flow of the 3 piece suits, with that Mono(over)price Cat6 cable mentioned above. Again, overkill but it's nice (and expensive).
SD
View attachment 27914 View attachment 27912 View attachment 27913 View attachment 27915 View attachment 27916 View attachment 27917
Awesome post. Just note that (now) the ebay link is for a CCA cable and not the pure cable. The original post I'd bet likely was correct but they've changed it.
