And I'm employing my top assistants to help...
Where's that big fat bastard you had in another clip recently?And I'm employing my top assistants to help...
Way to geek out and ruin the alien hypothesis!The lights appears to dim is from the power adaptors MFC (Multifunction controller).
Newer lights (2015 onwards) started using 2 wires to control the 2 channels of the lights, instead of 3 wires.
Instead of having a common and two wires to switch on/off for the patterns, the LEDs are now wired in reverse polarity to each other.
The MFC uses an H-Bridge circuit to reverse the polarity very quickly so all the LEDs appear to work at once.
Then there is two frequencies at play;
A constant 'carrier frequency' of which the H-bridge alternates the polarity.
and then a PWM duty cycle applied to fade the LEDs as part of their effects.
An H-bridge is a circuit commonly used to drive a DC motor. It allows the polarity (direction of current) to be changed.
Yeah that big black stomach with legs.Oh the big black one? That’s a neighbors assistant.![]()
Maybe it was wired by aliens?Exactly what I was thinking…..That or aliens
A similar situation is when a camera is recording a helicopter and the rotor blades appear to be frozen because the frequency of the RPMs and the frames match up exactly. In this case the frequency is slightly off, so using the helicopter example again, it would appear as if the blades are moving very slowly.
OK, that makes sense. But I was hoping for aliens.The frequency on these lights must closely, but not exactly match the camera's frame rate. This creates a scenario where the lights appear "on" when the majority of frames are catching the LEDs when "on", but the frequencies don't match exactly which makes the lights appear to dim down to as more and more frames capture the "off" cycle of the LEDs
It's definitely a "frequency" issue between the LED lights and the camera's frame rate. All LEDs flicker, it's just too fast for the eye to perceive it. The frequency on these lights along must closely, but not exactly match the camera's frame rate. This creates a scenario where the lights appear "on" when the majority of frames are catching the LEDs when "on", but the frequency is slightly off and so the lights appear to dim down to as more and more frames capture the "off" cycle of the LEDs. The appear off when the majority of frames capture the "off" cycle of the LEDs, and then they slowly dim back on as the frame rate captures more and more "on" cycles of the LED. If the frequency/frame rater were mismatched more, the lights would appear to blink. But since they are so close in frequency, they appear to fade in and out over a longer period of time. For example, frequency of the lights might be 59hz and the camera is recording at 60hz, etc.
The Bourbon helped!
So it does have to do with Exposure...
In this clip of the 5442H-ZHE I go from my normal setting- 3-7ms to:
Finally on AUTO it quits dimming.
- 1/250
 - 1/500
 - 1/1000
 - then to AUTO
But then I've still got aliens, watch and listen to what happens on AUTO....and this repeats much like the lights were...
On the 5442 S2 turret, no alien gremlins but AUTO does cure the dimming
- Normal setting 0-41/500
 - AUTO
 - Then I turn off IR
 and then backed up with @Mark_M technical explanation
 yeah pretty much figured it did... but the Auto issues on the Z and the noise are aliensyeah pretty much figured it did... but the Auto issues on the Z and the noise are aliens
 A similar situation is when a camera is recording a helicopter and the rotor blades appear to be frozen because the frequency of the RPMs and the frames match up exactly. In this case the frequency is slightly off, so using the helicopter example again, it would appear as if the blades are moving very slowly. Of course rotor blades don't blink on/off so that element is missing from this example, but hopefully that helps people understand it conceptually.
