Weird things with Christmas lights
bigredfish
26,176
69,166
The Swamp
Well at first I was going to say maybe it was shutter related with frequency mismatches of the bulbs and shutters but it would be weird that it would happen both day and night. The night made a sound when they lit back up - was that from that or something else?
Reactions: JDreaming
Yeah the sound is a weird thing that also just started when I enable sound detection on that one cam. Its not an external noise, cant hear it with my face 6" from the camera... but I'm pretty sure its aliens. The lights on the other hand are freaking me out
It can't be a sync thing with the bulbs/shutter as they slowly dim and slowly brighten, over a several second interval. And you say that you cannot see this with your eyes alone? What about filming with your smartphone?
It certainly is not like the flickering one sees with LED lights, like on cars recorded to security cams.
Wow, so Apple does not see it, a human does not see it, but Dahua sees it. Which begs the question, is it dimming or not? What is reality? I think you got it right already:
Or...Are the lights made in China? Probably. The Dahuas are made in China. What about your iPhone? I know you were not made in China. Maybe it is a Made In China thing?
You haven't seen it happen with your LPR cam? I have at a faster rate than this. Not often, but I get a weird LED headlight come thru here periodically that does that - usually it is the string type LED lights. I have seen it with my LED holiday lights as well.
Are these the exposure settings you found give the best picture for the 5442 and your NVR? Just getting ready to set mine up! Thank you!!
They work pretty well. I'm constantly fidgeting with them, and every scene is different.
The backyard is normally very dark, very little ambient light. If you have some light you can probably run the nighttime shutter a little faster, but yeah those should get you in the ballpark
In terms of getting the most out of the camera, here is my "standard" post that many use as a start for dialing in day and night that helps get the clean captures and help the camera recognize people and cars.
Start with:
H264
8192 bitrate
CBR
15FPS
15 iframes
Every field of view is different, but I have found you need contrast to usually be 6-8 higher than the brightness number at night.
We want the ability to freeze frame capture a clean image from the video at night, and that is only done with a shutter of 1/60 or faster. At night, default/auto may be on 1/12s shutter or worse to make the image bright.
In my opinion, shutter (exposure) and gain are the two most important parameters and then base the others off of it. Shutter is more important than FPS. It is the shutter speed that prevents motion blur, not FPS. 15 FPS is more than enough for surveillance cameras as we are not producing Hollywood movies. Match iframes to FPS. 15FPS is all that is usually needed.
Many people do not realize there is manual shutter that lets you adjust shutter and gain and a shutter priority that only lets you adjust shutter speed but not gain. The higher the gain, the bigger the noise and see-through ghosting start to appear because the noise is amplified. Most people select shutter priority and run a faster shutter than they should because it is likely being done at 100 gain, so it is actually defeating their purpose of a faster shutter.
Go into shutter settings and change to manual shutter and start with custom shutter as ms and change to 0-8.3ms and gain 0-50 (night) and 0-4ms exposure and 0-30 gain (day)for starters. Auto could have a shutter speed of 100ms or more with a gain at 100 and shutter priority could result in gain up at 100 which will contribute to significant ghosting and that blinding white you will get from the infrared or white light.
Now what you will notice immediately at night is that your image gets A LOT darker. That faster the shutter, the more light that is needed. But it is a balance. The nice bright night static image results in Casper blur and ghost during motion LOL. What do we want, a nice static image or a clean image when there is motion introduced to the scene?
In the daytime, if it is still too bright, then drop the 4ms down to 3ms then 2ms, etc. You have to play with it for your field of view.
Then at night, if it is too dark, then start adding ms to the time. Go to 10ms, 12ms, etc. until you find what you feel is acceptable as an image. Then have someone walk around and see if you can get a clean shot. Try not to go above 16.67ms (but certainly not above 30ms) as that tends to be the point where blur starts to occur. Conversely, if it is still bright, then drop down in time to get a faster shutter.
You can also adjust brightness and contrast to improve the image. But try not to go above 70 for anything and try to have contrast be at least 7-10 digits higher than brightness.
You can also add some gain to brighten the image - but the higher the gain, the more ghosting you get. Some cameras can go to 70 or so before it is an issue and some can't go over 50.
But adjusting those two settings will have the biggest impact. The next one is noise reduction. Want to keep that as low as possible. Depending on the amount of light you have, you might be able to get down to 40 or so at night (again camera dependent) and 20-30 during the day, but take it as low as you can before it gets too noisy. Again this one is a balance as well. Too smooth and no noise can result in soft images and contribute to blur.
Do not use backlight features until you have exhausted every other parameter setting. And if you do have to use backlight, take it down as low as possible.
After every setting adjustment, have someone walk around outside and see if you can freeze-frame to get a clean image. If not, keep changing until you do. Clean motion pictures are what we are after, not a clean static image.
I see quick flickering on some cams from LED lights, like daytime running lights on my JGC. But never something that goes off for a few seconds then on again, like BRF and @Ri22o is showing.
Yeah, most are faster. It's obviously not going off/on slowly as it seems. You'd see that with your eyes. I think that it's more that whatever the frequency overlap happens to be makes it appear to cycle on that timing.
