VPN Primer for Noobs
  • Total voters
    868
Yea I'm not so sure about TeamViewer. I tried setting up nomachine on my parents laptops to help them with computer issues but for some reason it couldn't configure their router on its own to access over the Internet. TeamViewer had no issues doing that. That's when I decided to buy them a $10 router from Craigslist, install dd-wrt and set it up as a VPN server. The tax document transfer in my case is just a bonus for using a secure VPN. For minor computer issues in the mean time I'll still use TeamViewer just because it's working.
might set yer mom up with a PGP Mail Addon and a key, then you can send files/data back and forth securely over public systems.
Ha, thanks. Don't know what that is or that even existed as an option, but maybe I'll look into it just to see what it's about.
The primary goal for me was to remote into their computers to help them out with whatever issues they may have, so a secure remote desktop control is my primary goal. The secure transfer of files is like a bonus.
Although even though they only live 1.5 hrs away I probably already don't visit them enough and could use extra reasons to get down there.
For example my mom just got a new laptop. Well, until she was able to get all of her tax programs and documents moved over to the new computer, she was putting files on flash drives, then moving over to old laptop to print. Then she figured out that she could just move the printer cable between computers and print like that. Sigh... I figured out she has a Ethernet port in the back of the printer so my last trip down there was to get that on their network so they could all print easily. (my dad's laptop printed thru the shared printer from her old laptop, so if she had hers out of town he couldn't print. Thanks Geeks quad. I wasn't about to let them take another $99 from them for hooking their printer up to the new laptop in such a shitty configuration. She's got a heavy duty printer since she works at home)
They're always amazed at what I can do to fix their computer/phone issues. What's the saying? You only have to be the smartest person in the room to be labeled an expert? I am certainly no network/computer expert and Luckily they have easy issues to resolve Haha.
Lol daviddavid. I've discovered that even if I know how to fix a tech problem for someone (which is often) its best to keep my mouth shut. Otherwise I'm doing a bunch of free work heh
After all the stuff that has just come out about CIA \ NSA hacking tools being able to basically access everything at any time...you think there really is any secure transfer of data that cannot be monitored?...and probably more easily than we know.
I'm safe though...All my communications have been flagged as so boring the CIA said they added me to their block list. o_O
Hey, if the government intercepts my tax documents then it'll save us the hassle of filing them!
Thanks for this primer! I have both BI and OpenVPN set up on a dedicated desktop PC and have successfully accessed my Blue Iris webserver from my Android phone thru my cell provider network.
Can you all suggest the best way to remote in to the OpenVPN / BI server. I've used Teamviewer in the past to help family with PC issues, but part of installing OpenVPN was to have a more secure remote access. I'm looking to be able to use my VPN to remote control desktop, do file transfers, etc from both Android and windows PCs. And have to stick with TUN as I understand Android doesn't support TAP I believe.
just use the built in Remote Desktop functionality
Reactions: slowhandfan
Thanks @nayr, I've used that before but didn't know if there was a better option.
I also want to be sure I haven't created any problems on my network. I ran GRC Shields up and all ports are stealthed, no port forwards on my router except for OpenVPN. I was also thinking I should block outgoing traffic on my cameras to avoid them being used by hackers, does that make sense to do? Any other suggestions / tools to check my network? Really appreciate the help!
Block your cameras from reaching the internet by all means, however you might have issues with emails and timesync if you dont run those services your self locally.
OK, I don't run my own email or timesync, will have to think about that and do some research. Want to be a good net citizen as far as my limited networking skills will allow.
@nayr, is it possible (or smart) to set your router NTP to the NTP server on our BI machine if we have one running? Or is it better to have it sync to an outside NTP?
sync it from your local network, then you'll recover time after an outage if the internet is gone.. doubtfull your router has a battery backed up RTC
At least Openvpn wasn't listed which I use as well.
