- Oct 2, 2014
- 210
- 47
First i wanted to make the distribution block myself since its from HDPE and very simple to make but i have not much time so i thought well , ill just order it.
Now i hope this week the concrete floor will be poured on the tubes and another thing is done.
I needed the exact measurements for my building for the floor heating/insulation for the roof etc and i used them to make a drawing in sweet home 3d.
It came out quite nice i must add
Some of the fronts i needed to make for my cove in the living room are made from MDF, i used a hand mill to take out a part that would slide on the edge.
I have made some by hand first and for 10 pieces it took almost 6 or 7 hours and allot of dust.
Friend of mine uses allot of woodworking machines making window frames and well actually everything at his work.
It didn't take 10 minutes in total for 20 pieces .....
Here is a video : Yahoo - login
What are you talking about, well these fronts i mean that prevent you from looking into the led strips
Also bought a PTZ IP cam with a Sony imx178 sensor and it is amazing i must say.
A bit big but works good , i hanged it with some tywraps the same evening on my testing pole haha.
Little update again
I did some bidding on a auction and "won".
I went to the place to pick the stuff up but i had to do a job nearby, i used the car of the guy that hired me.
its a Mitsubishi phev something, nice for longer stuff but it was to small to put everything in it that i had won...
So allot of stuff i had to leave behind, learned my lessons for the next time.
Still a good bargain, allot of tools and electric valves, draka wire and that for 200 €
the Flowmeter that you see can be connected by pulses or modbus and some other connection types , going to use this for my rainwater system ;0
Just for fun to see how many rain is going trough.
Shocked about the price it would cost when buying new, bought it for 10€
had to do some work on the plaster plates in the hallway , drilling the holes for the lights and fire alarm.
And i needed some space to put my stuff in because the space i had was being filled rapidly with stuff laying everywhere.
Found this nice rack for just 75€ on marktplaats.
Also that day i bought some steel pipes for my heating system upstairs.
If the floorheating is not doing great or i want LT radiators for heating/cooling i have it already there just to connect and done.
needed the size of the new bath for in the bathroom to see if it would fit and where i must prefab the connections,
so i drew it on a piece of insulation
placing the shower drain took some time and the sewer pipes that had to be under a small angle .
beneath the bathroom i needed to see what was behind the wall and here is the location where the sewer/shower heat exchanger is going to be so i needed to cut there.
Lighting wires in the hallway on the 1st floor.
Then i decided it was time to build the rack to get some space downstairs and upstairs in the garage,
i had some old wood laying around coming from a big old closet that i used to make more room.
Then it was time to bend the steel heating pipes and use a hose to protect it for the concrete "acid" or whatever is in it to eat the metal.
The insulation material arrived for my roof from the house and garage.
I asked the company if the transport company could call me 30 min before the drop off and they said sure no problem.
Sitting downstairs at my parents house from 7.00 doing some bookkeeping and waiting on the phone call.
At 10.15 i when i was done i drove to my home and this is what i found.
Yes great, its there, but now i had to walk everything inside by hand....
So that took enough time and trash that i had to bring to the dump but well its here
Little update again
