so what is the difference between this model and DS-2CD2345-i
I don't know if anyone knows at this point. In some places it looks the same spec as DS-2CD2342-i but cheaper. I contacted one of the resellers to get a screenshot of the label to verify.Does anyone know the answer to this question? Thanks.
Tell me what to do and I'll hook up my laptop to mine.Apart from the 2CD3345 DSP supporting H.265 and the 2CD2342 supporting H.264 and the specifications of the 2CD2342 claiming 120dB true wide dynamic range rather than a digitally-processed WDR of the 2CD3345, and the difference in claimed low-light sensitivity, a confirmation of the sensors used could differentiate them.
A look at the serial console during startup shows that the 2CD3345 has the Omnivision OV4689 sensor, here: http://www.ovt.com/products/sensor.php?id=136
If anyone has a copy of the serial console during startup of the 2CD2342 we could confirm what sensor is used there as it's not something Hikvision has been known to document.
So, Daylight pics, night coming soon
First able, here is a pic of the cam itself and would like to share with you what hikvision have change
the way of install the camera
Here is the back of the cam, the DS-2CD3345-I is on left side, on right side i put a DS-2CD2332-I to show
you differences (scale is cm )
PLASTIC yes bunch of plastic for DS-2CD3345-I
disassemble, always plastic
Let's go to see how to put it on a wall !!!
You have to disassemble to place it because the screws are not on the side like "old camera"
you have to screw the plate and after place the camera
i've put red circle, for the screws of the DS-2CD2332-I to show you how thinner the new cam is, i have re-use one of the 3 screw hole
@Del Boy - to get this info I used the serial console connection - a serial TTL to USB convertor plugged in to the camera board.Tell me what to do and I'll hook up my laptop to mine.
davinci receive cmd_query_davinci_param.
S: cmd_query_davinci_param
insert audio
==== Your input Sensor type is ov4689 ====
[09-19 20:11:45][pid:0][SYSINIT][ERROR]getDevHardInfo!.
[09-19 20:11:45][pid:0][SYSINIT][ERROR]device not support RS485
[09-19 20:11:45][pid:0][HW_IF][ERROR]r2 transfer_485_config_options error [options:57]
[armlib]armlib build at 20:02:07--May 7 2015
[armlib]shmKey = 0, DSPINITPARA share size = 548464, addr 0xb602f000
arm creat registerSemaphore userId 100 semId 0 done
arm creat registerSemaphore userId 101 semId 32769 done
[armlib]init_dsp_lib ok!!!!!
hello,
What synology did you use with this camera and what camera did you select? becaus the chinese hikvision models are not supported officially.
I have the same camera with a DS215j and I experience severe hiccups while my DS-7100 hd recorder does not show this behaviour.
