- Nov 23, 2017
- 467
- 193
Since you're a good POC now (haha!) if you would ask, I would like more beams run at less power. I know the circuit he's got in the back end there and shiver while it's OK, there's a reason laser power supplies have a few more components. The chip is the standard one used in most of those IR illuminators- I found spec sheet once- it has an option for a CdS sensor to turn on/off. Otherwise you have to use a relay to the 12V adapter.
So... yeah... these MCPCBs fit the standard housing too- you could run it at 1/3 the current per Laser and they should last forever.
1.5US $ 12% OFF|Led Pcb 6w 9w Rgb Floodlight Aluminum Plate Heatsink High Power Pcb Plate For Led Light Outdoor Light Landscape Floodlight Lamps - Floodlights - AliExpress
Smarter Shopping, Better Living! Aliexpress.comwww.aliexpress.com
Also- you said the 2ndary lense was removable ? I'd want to buy a batch of the 'next focal' length up. I think 7 degrees would work, but 15 or 30. I don't care if they sit on my shelf, they can join all the other stuff![]()
I tried and couldn't find these hexagon housing laser lens anywhere(AliExpress ebay, digikey...) Maybe in using the wrong search terms. I did messaged this seller before and he don't sell the lens separately.
He is willing to customize the power and I think the next step up is 30 degree lens.
