Tesla PowerwallTesla Powerwall
I am watching most things Elon does. I like the concept of the Powerwall but not totally critical for me now. I do have UPCs by all of my POE switches. I consider them another device with a battery to maintain.One 14 kWh Powerwall battery $5,500
Installation and supporting hardware starts at $1,500
Total estimate $7,000
Requires $500 deposit for each Powerwall
You buyin?
LOL, i got several of them, even one for EU. They are more accurate than most people think, so long as the voltage is within ratings, so stock upEvery self respecting nerd should have one of these in the tool bag: P3 P4400 Kill A Watt Electricity Usage Monitor - Low Temperature Alarms - Amazon.com
buy two their small, or buy two in case one breaks, whichever you prefer :0 ) In all seriousness, it is a pretty good value compared to the norm.One 14 kWh Powerwall battery $5,500
You buyin?
If you run natural gas, you can install a generac or similar system for half the price and have infinite power...buy two their small, or buy two in case one breaks, whichever you prefer :0 ) In all seriousness, it is a pretty good value compared to the norm.
You are not understanding. If you have a NATURAL gas powered generator, you have unlimited supply of power. All you need is a cheap 50-100 dollar ups and you are good to go. A $7000 battery is silly unless you have solar and can store extra power for nighttime use.one does not replace the other. a generator still needs a UPS, just less time (Watt hr) is needed. the same power (watts) is needed however, so there is still that cost. A good data center generator will start and deliver stable load in under 8 seconds every time. a residential class generator might take 60 seconds to stabilize and deliver reliable output. if your power is out for 3 days... you are likely SOL no matter what you do as you will be out of gas and wont be on the short list to get more. Zombie apocalypse always comes down to bullets.
That's another thing, our power if fed through via underground, as well as our meters are tucked within the premises, nothing exposed outside. Another aspect of UPS's is that in the event of power outage, we're only talking about 20 minutes up to an hour of backup power, until that goes offline as well.
Its great to consider every possible variable. Would a UPS still be feasible here?
One thing to look out for is if they're discarding UPSes at your workplace. Often times when the batteries go a perfectly good UPS seems dead (ie won't power up). So these typically get tossed.
I picked up a beastly APC SmartUPS from the trash bin at work. I stuck in a new set of batteries and it works great. This particular UPS also supports reprogramming to handle an external battery pack, so I added another battery pack. It ran my desktop computer at idle (monitor off) and wifi router for 4 hours during a power outage once.
