The transition from the silent weightlessness of deep space to the heavy, vibrating reality of Earth is the most physically demanding part of the entire mission. For the crew, it’s a sensory transition that moves from "nothing" to "everything" in a matter of minutes.
1. The Sudden Return of Gravity​
After days of floating, gravity doesn't return gradually; it hits like a physical weight.
  • The First "G": As Orion touches the upper atmosphere, the crew will feel a light "tug" into their seats. It’s the first time they’ve felt their own weight since leaving Earth.
  • The Peak Load: Within minutes, that weight multiplies. At peak deceleration, they will feel about 7g's to 8g's. To put that in perspective, a 180lb astronaut will feel like they weigh over 1,300lbs. Breathing becomes difficult, and even lifting an arm to reach a control panel requires massive effort.
2. The Sound and Vibration​
In space, there is no sound outside the ship. During reentry, the environment becomes incredibly loud.
  • The Roar: As the air thickens, the sound transitions from a high-pitched whistle to a deep, thunderous roar. It’s the sound of air being compressed and pushed aside at Mach 30.
  • The Buffeting: The ride is far from smooth. The capsule will shake and vibrate violently (often called "the paint shaker" phase) as it passes through different layers of air pressure and performs steering maneuvers to stay on course.
3. The Visual Spectacle​
Looking out the small windows, the view is both beautiful and terrifying.
  • The Plasma Fire: The crew won't see blue sky at first. They will see a wall of bright pink, orange, and magenta fire. This is the air outside ionizing into plasma.
  • The Blackout: During this time, they are encased in a "fireball" that blocks all radio communication. For about 7 to 11 minutes, they are completely alone, unable to speak to Mission Control, watching the plasma lick the windows just inches from their faces.
4. The "Jolt" of the Chutes​
Once the fireball fades and the ship slows, the final sensations are sudden mechanical shocks:
  • The Drogue Snap: When the two drogue parachutes fire at 25,000 feet, the crew feels a violent "jolt" as the chutes grab the air and stabilize the tumbling capsule.
  • The Main Deployment: A few minutes later, at 9,000 feet, the three main chutes unfurl. The capsule will swing and oscillate significantly—enough to cause motion sickness—before settling into a slow, rhythmic drift.
5. The Splashdown​
The final "feel" is the impact with the water. Even with the parachutes, the capsule hits the Pacific at about 20mph. It’s often described by past astronauts as a "car crash" sensation—a sudden, blunt thud followed by the disorienting feeling of bobbing on ocean waves, which can be quite nauseating after days in a stable, weightless environment.
  • Love
Reactions: Arjun and johnfitz
  • The Peak Load: Within minutes, that weight multiplies. At peak deceleration, they will feel about $7g$ to $8g$. To put that in perspective, a $180$ lb astronaut will feel like they weigh over $1,300$ lbs. Breathing becomes difficult, and even lifting an arm to reach a control panel requires massive effort.
5. The Splashdown​
The final "feel" is the impact with the water. Even with the parachutes, the capsule hits the Pacific at about $20$ mph. It’s often described by past astronauts as a "car crash" sensation—a sudden, blunt thud followed by the disorienting feeling of bobbing on ocean waves, which can be quite nauseating after days in a stable, weightless environment.
One last shot before the world goes BOOM
The "Good News" Context​
It is important to note that while 33,000 is a high number, it represents a 55% decrease in veteran homelessness since 2010. Programs like HUD-VASH (which pairs housing vouchers with social work) have proven that when veterans are given stable housing first, they are far more successful at then addressing personal challenges like health or employment.
Reactions: johnfitz
