- Sep 5, 2015
- 759
- 608
I don't know, try disabling 3/4 of the cameras and see if you can get it to run with 5-10 cameras. Since it's an 8th generation Intel chip you should read the thread that has info on the Intel memory leak.
DO you have a link for the same? I think ive practically almost read everything on this troubleshooting section of Blue Iris now!I don't know, try disabling 3/4 of the cameras and see if you can get it to run with 5-10 cameras. Since it's an 8th generation Intel chip you should read the thread that has info on the Intel memory leak.
I Hope so! but what is the reason for the CPU to Max out like this? Any Idea?Sounds better. Now just add a camera at a time and watch the CPU. Should be able to finish it from here.
We are observing the CPU usage going upto 100% on web login and dropping as soon as logged out.. any thoughts?
