tangent
- May 12, 2016
- 4,641
- 3,997
On NVRs with PoE ports built in:
-Only cameras can be connected to the PoE ports
-The PoE ports are isolated from eachother and the rest of the network
-Other devices connect to the NVR to view the cameras, sometimes there's a way to access cameras directly through the NVR to adjust settings.
-The NVR will only record up to some number of cameras. Adding a switch doesn't expand the capacity.
-NVRs typically use a different subnet for cameras connected directly, typically something in the 10.x.x.x range.
Often it is possible for NVRs to record from a source on the LAN side of the network. But, you lose one of the PoE ports (fixed number of cams it can record)
Cameras are often assigned static IP addresses and might not just up in a router's status page and could be assigned IPs on a different subnet. Your mange switch could also be configured in a way that causes unexpected behavior.
