1/3",progressive scan,CMOSWhat Uniview spec camera is this pal?
No as in is it the 4mp, 5mp, colour vu which type?1/3",progressive scan,CMOS
• Up to 2592×1520 resolution,20fps
• 2.8mm/3.6mm optional
• Smart IR, up to 30m IR distance
Is4mp color.
This spec don’t retain colour they’re the standard B&W. A lot depends on your connection also. Try adjusting the frame rate slightly see how you get on4mp color.
Is
Ah I see… yes pal try lower that and follow some of the above settings. A lot of it’s trial and error. Took me a while. I have however turned off the white light that keeps full colour but I’ve a PIR light that covers the driveway also- helps keep a clearer imageI notice a ton of ghosting even in the day. So a lower frame rate ?
