This spec don’t retain colour they’re the standard B&W. A lot depends on your connection also. Try adjusting the frame rate slightly see how you get on
Ah I see… yes pal try lower that and follow some of the above settings. A lot of it’s trial and error. Took me a while. I have however turned off the white light that keeps full colour but I’ve a PIR light that covers the driveway also- helps keep a clearer image
