Unifi AI Port- Works great!
Is this working with the EmpireTech IPC-B52IR-Z12E-S2 (IPC-HFW5241E-Z12E) running the latest firmware?
Correct; AI Port treats every ONVIF device the same
Reactions: quiet.tea
I have this same albeit older camera (IPC-HFW5241E-Z12E) streamed to Blue Iris and now also to Protest, and the AI Port is using it to tag plates and people.
Reactions: Arjun
Nice! How many ONVIF devices can it support at this moment? Also, is there still an issue with the capture of plates after dark?
That was a surprise to me when I got the AI Port, that it need not even be connected to a camera, it just needed to be on the network. I have 4 ONVIF cameras as well as the G4 on the Protect. The use of plate collection, though, is weak even during the day. My Z12 is also on Blue Iris, and I have a Rekor account for collecting plates, and the Rekor captures most while the AI Port can miss maybe half. The AI Port would be useful for a business where the camera is directly in front of the cars, say, in a corporate parking lot. But for LPR, I am staying with BI and Rekor.
Reactions: Arjun
Up to 5 UniFi Cameras, only 1 ONVIF device at the moment
Thank you for sharing your experience. I was contemplating buying one but I'll have to pass for now if it is only capturing half the plates compared to the Rekor.
Reactions: Arjun
I ordered the AI Port to evaluate its performance and paired it with an Axis P1468-LE 4K camera. Vehicle, person, and license plate recognition work very well, but face and animal detection leave a lot to be desired. One thing that really surprised me is that the maximum supported recording bitrate is capped at just 8 Mbps (see "Video compression" in the attached screenshot), while the camera actually streams at 20–30 Mbps. Is this a bug on my end, or are others experiencing the same limitation? Overall, I'm quite happy with the product, but this could be a dealbreaker for me.
Reactions: Arjun
It also seems that the AI Port itself can’t process a stream at 20 to 30 Mbps. I hadn’t noticed it at first, but after reviewing some of the recordings, I realized that many of them have brief skips—usually missing about a second of video. I compared them to recordings made at the same time by Blue Iris, and those didn’t show the same issue.
Reactions: Arjun
I can imagine plates just slipping through the cracks due to bad bitrate :( Thanks for pointing that out
License plate recognition has actually worked really well for me with Dutch plates. I reached out to Ubiquiti because I find it hard to believe that the AI Port only supports an 8 Mbps output stream—it seems more like a bug to me. Unfortunately, their support hasn’t been very helpful so far.
I was hoping someone else here has tested a 4K camera and managed to get higher bitrates. Anyone?
Reactions: quiet.tea and Arjun
I've been in ongoing communication with Ubiquiti support over the past week, and it turns out that the AI Port only supports a maximum bitrate of 8 Mbps. It also transcodes the incoming video stream into a different format for the outgoing stream. This means that the high-quality video from my Axis P1468-LE is significantly degraded when recorded by Protect. Needless to say, I ended up returning the AI Port.
  • Sad
Reactions: Arjun and quiet.tea
it looks like now is possible to do 4 cams at 4MP (2K) (like 5442 or 3449) or 2 4K cams at once on one AI Port (199 USD or 222 EURO)...
EDITED:
But I had read one more time the changelog and found that is about UI cameras not ONVIF ones :(
So we need to wait for another firmware update with multiple ONVIF cam support...
Latest firmware update:
Overview​
UniFi Protect AI Port 4.75.3 includes the improvement listed below.
Improvements​
  • Added support for multiple UI cameras, enabling the use of up to 5 HD cameras, 4 2K cameras, or 2 4K cameras.
Reactions: MTL4 and quiet.tea
You can create a stream profile in the Axis camera for the AI Port and use Maximum bitrate instead of variable. When you choose Maximum for bitrate type, you can enter the maximum bitrate as 8 Mbps. This will only affect devices using that stream profile and won't affect BI. Also, if the P1468-LE is normally streaming between 20-30 Mbps a settings is off. Normally, mine is between 2-15 Mbps depending on how busy the scene is, where it only jumps to 15 Mbps momentarily. I would only see the camera streaming at or over 20 Mbps when the entire image is filled with moving objects such as a heavy snow storm.
You can have multiple different stream profiles that have different bitrate settings with that camera.
Yeah, I’m aware that I could set up an ONVIF stream profile on the Axis camera with a max bitrate of 8 Mbps. But honestly, that kind of defeats the purpose of investing in a high-end camera like the P1468-LE. I want the camera to be able to use the full range of its encoding capabilities and push up to 15–20 Mbps when there's a lot of activity in the scene. Capping it at 8 Mbps just to accommodate the AI Port feels like I'm nerfing the camera’s potential.
Reactions: smiticans
I agree, I just wasn't sure if you were using the AI port in addition to BI.
Just an update here; make sure you update to the latest firmware of AI Port; works amazingly well now; make sure night and daytime LPR camera settings are fine-tuned. :D. Note the changes in UniFi Protect web user interface as well; especially when looking up plates.
Does it work well at night after the upgrade?
I may have sounded the bell too soon because it has been less than 24 hours for me since performing the update and tinkering with the settings. I'm still tweaking the night settings; its more of a settings issue within the camera itself versus UniFi Protect; also still using CodeProject AI with Blue Iris; will report back as soon as I dial out the settings :)
Upon further testing; Daytime to evening the AI Port works almost flawlessly; however, at night - despite nailing the settings for nighttime LPR, the AI Port fails to pick up any license plates; makes no sense whatsoever; I have the camera settings dialed virtually perfectly; I even have HLC on. I can freeze frame each car and see the license plate perfectly. I am recording at 30fps.
