fenderman
Staff member
- Mar 9, 2014
- 36,891
- 21,417
You are mistaken. The power draw on your system is at least 100w MORE than a new i5 or i7.The machine is plenty powerful. It simply doesn't have that particular feature that Blue Iris uses. I've had the machine plugged in and running for over eight years and my bills are just fine. The base power draw on it vs a brand new i7 isn't any different. They just cram more cores/features into the newer chips w/the smaller build process. You can't really compare the power draw of an i7 to an i3 of any generation, the two chips were designed with completely different intentions in mind. I have a 5820K w/16GB and SSD as my primary machine, I just don't care to sacrifice it as a glorified video recorder. The question is whether I care to spend $300-500 right now on a new cpu/motherboard/ram. Saving myself $4-5 in electricity per month doesn't really justify it (though that sounds like a compelling argument for the wife)
http://www.tomshardware.com/reviews/overclock-core-i7,2268-10.html
Likely more than 100w...remember that your system is using dedicated graphics because there is not onboard graphics. First gen i systems were not efficient. There has been significant imprevent in the later 3rd and 4th gen. For example see this info on an i5-4590 power draw. https://www.ipcamtalk.com/showthread.php/5696-PC-NVR-Power-Consumption-Sample?highlight=consumption
That i5 is not only at least 50 percent more powerful than your system, it supports hardware acceleration making it about 80 percent more powerful with respect to blue iris. Those systems can be purchased for about 200-300. The i5-ivy bridge can be had for 150-200.
The difference is not 4-5 dollars a month. Put your machine on a killawatt meter. You are wasting 15-25 dollars a month depending on your rates. Since you can buy an effcient system for 150-200, your paying the electric company for nothing. They fact that you have wasted 100+ dollars per year of 8 years is irrelevant.
FYI, The 5820k is a terrible choice for a blue iris machine...its is a power hog and does not support intel graphics...
Do the math, you will see that you are saving enough to by a nice system. Buy a killawatt meter its a great investment.
