Hi,
i need some help with my NVR.
After a third Party Camera did not work correct i restarted my NVR (at this moment the 3 Dahua Cams worked fine).
After a few Minutes i tried to open the Webinterface but got no response.
When i checked the NVR Hardware and connect an Screen it Only shows NVR 4.0 and it beeps one time.
I tried to connect via serial and got this Log.
After a few minutes the system reboots automatically.
I already tried to interrupt the boot and flash the nvr via tftp but i did not get any response on the console (tried * and also Shift+8).
Any Idea?
Marcel
Code:
MMC:
EMMC/MMC/SD controller initialization.
Device is not exit !
MMC/SD Card:
MID: 0x15
Read Block: 512 Bytes
Write Block: 512 Bytes
Chip Size: 59632M Bytes (High Capacity)
Chip Type: MMC
Version: 4.0
Speed: 25000000Hz
Bus Width: 8bit
Boot Addr: 0 Bytes
MMC read: dev # 0, block # 4096, count 2048 ... 2048 blocks read: OK
U-Boot 2010.06-svn5643 (Nov 24 2021 - 17:06:41)
MMC: In: serial
Out: serial
Err: serial
squashfs use gzip
SCU: load slave image OK
spi env sysbackup=0
Read backup misc byte ...
erase_misc_byte ok!
backup tc exist !!!
backup rc exist !!!
ok!
PRODUCT:>1U
Hit any key to stop autoboot: 0
Any Idea?
Marcel
