welp.. it doesn't say it's not on the list of connected devices although the ethernet cable is plugged in and the lights are onLook at your router for the IP address of the NVR.
This worked like a charm! Guys, you all here are a treasure chest of knowledge! Really appreciate all of your help.Another option:
Run the Amcrest IP Config tool on your Windows PC and it should tell you the NVR IP address, etc., if the NVR is working and connected to your LAN. If NVR is not working, try a unplug/replug power to reboot it.
