observant1
Getting comfortable
If it's plugged into a smart switch, you may need to make sure the port it's plugged into is configured properly. - just a shot in the dark.
Yes!Does Config Tool find devices that are on a different subnet as the PC it's installed/runnning on?
I'm off to go find a 12v PoE injector.
And often struggled/wondered if a nonsmart poe switch
Would just pass traffic packets regardless of two different sub nets.
Just to clarify the terms, an "injector" , in the IP camera realm at least, implies a device that puts voltage and data on the Ethernet cable to a POE camera.Tony, my mistake on the voltage, turns out both the TP Link and Unifi are 24vdc. I should pick up a 12v injector for future use, might save some headaches and make the whole process easier. Thanks for your help.
