fenderman
Staff member
- Mar 9, 2014
- 36,891
- 21,410
The reolink 410 is a 4mp or 5mp camera depending on version NOT a 4k, so if you meant 4k you are wrong.Yes I meant 4K.
That sounds a little technical for me but I have not had any issues with them. I find most other camera require regular reboot but the reolinks have not been reboot in over a year.
I have found BI to be head strong with frame rates. I have to constantly change it back to 24fps. For some unknown reason it changes to between 27fps and 33fps. This happens with a another installation I have set to 15fps. I know this has happen when the CPU usage jumps up to over 90%.
you dont have a problem. The frame rate will remain as set in the camera as you can see in your blue iris status page unless the CAMERA is sending more.Well. The installation requires 99.9999% SLA so all the CCTV equipment sits on 1 x 15kva and 2 x 6kvA UPS's.
You are obviously more technical than I am so I will leave the Reolink topic.
See below for another installation that isn't using Reolink and has the same problem.
