That's the so-called 'recovery mode' that's entered after incompatible firmware has been loaded."V4.0.8build 150401"
This forum does seem to be the best collection of what's out there in public for Hikvision.Is there any chance someone's done a writeup that has all the serial and firmware update knowledge in one place? Or is that an unreasonable thing to think given the way Hikvision hates their customers?
Depending on the version of the updater program that the tftp update process kicks off, the camera can just sit there at the default 192.0.0.64 address with telnet and ftpd active waiting to be power cycled.none of them reboot after the firmware has been updated.
- At this point it is possible to simply change the ‘Language flag’ by executing the following command, using ‘1’ for English or Multi, and ‘2’ for Chinese device. If you want flash english firmware to chinese IPC or NVR you need set language to 2:
hiktools lang digicap.dav 2
With apologies for the dumb question - but presumably you've waited 5 mins (the firmware flash process is quietly taking place after file transmit and can take 3-4 mins) then power-cycled the camera, watching if it appears on SADP?They just stall at "Completed file[D:\util\hikvision\downgrader\digicap.dav] transmit"
Greetings from Finland and thanks a lot, you saved my DS-2CD3132F-IWS from a trash can! I was able to restore it back to life (with v5.2.5) it using your instructions!So, no worries, your camera is not fully bricked if it's not booting. It just needs a bit of effort to recover. I should say that my other 2CD2332 camera has a similar connector plug on it, so they probably put it on all IPCs in the 2 model line. Hope it's helpful for someone.
Does anyone know the size of molex connector on the 2CD2132 Dome cameras?
I ordered the TTL UART which came with fly leads, but they don't fit. And my local components store don't fancy pulling out all their molex connectors to find the right size :/
Some Reference material incase you need to deep dive the solution.
http://www.savagehomeautomation.com/projects/raspberry-pi-rs232-serial-interface-options-revisit.html
