This is what started my hunt -- Day time "ghost plates".
I attempted to make my setup all B/W but I got that in the day.. no plate cover, no obfuscation, yes a poor angle, that was I believe 80% zoom?
It looks like an MA plate is very reflective but the letters, so they pop out under heavy IR. I think the problem in the day is that its so bright out, the entire plate is reflecting
If you're getting car but zero plate at all, I think you need much more IR. Would an external IR light work?
I think you just need to tweak the camera settings. You have too much of the car at night. The car should be totally black.
Edit: Maybe I was looking at your daytime pic and not your night because I do see you have the car as black in the above post but no plate. Were you sure that car had a front plate? Are you wanting to run B/W 24/7 to avoid the focus issue? You can set a manual focus for both night and day. I've found that I get better captures of plates during the day time running color and I use B/W only at night.
Make sure you aren't a shutter range at night either. Try 1/1000 or 1/2000 fixed.
Your daytime is spot on! So that is progress.From this morning around the 730am -- Night B/W settings were changed before this image to 1/1000 fixed and 70-70 gain fixed all other settings were the same from the shot of the car with just headlights. Camera was operating in "night"
For reference that same car w/ day settings in color:
Night time gain is 70-70, daytime is 0-60Your daytime is spot on! So that is progress.
You said your gain range is 70-70?? That needs to be 0 - 50 range. That high of a gain will wash everything out.
My plate doesn't unless the state applies it.. or salt spray does this overtime..Could it be that the plate has some sort of PhotoBlocker spray on the plate?
^^ This may be your problem. Move to a range of 0 - 50 for B/W mode. Don't used a fixed gain. Ever. Unless you have 100% control of the illumination in a scene (i.e. movie studio). You need to always use a range.Night time gain is 70-70, daytime is 0-60
Well I was told to run fixed gain. The image with headlights and no plate was 10-50^^ This may be your problem. Move to a range of 0 - 50 for B/W mode.
In this thread you were told to run fixed gain??Well I was told to run fixed gain. The image with headlights and no plate was 10-50
