juched
@105437 @juched @Senor Pibb - For the odd display issues, make a shortcut to AITOOLS somewhere, right-click > properties > compatibility tab > change high dpi settings, and see if they help for the next time you start it. Or maybe edit aitools.exe.config and set the value for DpiAwareness to "false" rather than "PerMonitorV2". I have a 4k monitor set at 175% dpi and a 1080p monitor set at 100% and UI elements seem to be fine for both.
Thank you. I have tried all the various options already under High DPI settings, and none of them work. If I open the window While the TV is on, it works, but if I close the app and relaunch once the the TV is off, then it will not draw properly. Yes, when I turn the TV off the resolution changes, even if my TeamViewer is open while the TV turns off. So, it seems the High DPI setting doesn't work when a monitor is not attached (or is off).
Have not had the opportunity to try DpiAwareness option yet.
