below is the message i already sent to dahua support for my region, wonder if anyone here has any idea since i'm not getting a reply from the official boys:
i have two DH-IPC-HDW3449H-AS-PV-PRO cameras that throw an "Update failed" error when trying to sync time with a chrony server (cturra/ntp) running in a container on the same computer as my frigate NVR.
There's also an IPC-HDW5442TM-ASE-0280B-S3 on the same network running 260427 firmware with the same NTP settings that syncs just fine.
All cams are on a secondary NIC of the frigate box with static IPs and no way outside. NTP server is confed as an IP as well, so no NAT, DNS or any other network related complications involved. No router there, just an unmanaged Ubiquiti PoE switch.
tcpdump shows that the NTP server communicates properly - the traces are identical for the 5442 that syncs fine and the 3449 that does not (pasted at the end of this message)
Device Model
System Version
V3.140.0000000.38.R, Build Date: 2026-09-11
I also have two of HFW1439TL1 that are not connected right now, and I think they also used the NTP setup just fine when i was testing them. Not sure if that matters since a 5442 that's running right now works and is probably a lot closer to TiOC tech wise.
Here are the dumps from 5442 and 3449 respectively
Device Model
System Version
listening on any, link-type LINUX_SLL2 (Linux cooked v2), snapshot length 262144 bytes
20:38:23.709275 enp4s0 In IP 10.10.10.194.36095 > 10.10.10.1.123: NTPv4, Client, length 48
20:38:23.709322 br-64e46f527ce3 Out IP 10.10.10.194.36095 > 172.19.0.2.123: NTPv4, Client, length 48
20:38:23.709329 veth008b654 Out IP 10.10.10.194.36095 > 172.19.0.2.123: NTPv4, Client, length 48
20:38:23.709444 veth008b654 P IP 172.19.0.2.123 > 10.10.10.194.36095: NTPv4, Server, length 48
20:38:23.709444 br-64e46f527ce3 In IP 172.19.0.2.123 > 10.10.10.194.36095: NTPv4, Server, length 48
20:38:23.709470 enp4s0 Out IP 10.10.10.1.123 > 10.10.10.194.36095: NTPv4, Server, length 48
20:38:23.710882 enp4s0 In IP 10.10.10.194.36335 > 10.10.10.1.123: NTPv4, Client, length 48
20:38:23.710914 br-64e46f527ce3 Out IP 10.10.10.194.36335 > 172.19.0.2.123: NTPv4, Client, length 48
20:38:23.710919 veth008b654 Out IP 10.10.10.194.36335 > 172.19.0.2.123: NTPv4, Client, length 48
20:38:23.711005 veth008b654 P IP 172.19.0.2.123 > 10.10.10.194.36335: NTPv4, Server, length 48
20:38:23.711005 br-64e46f527ce3 In IP 172.19.0.2.123 > 10.10.10.194.36335: NTPv4, Server, length 48
20:38:23.711019 enp4s0 Out IP 10.10.10.1.123 > 10.10.10.194.36335: NTPv4, Server, length 48
20:38:23.712136 enp4s0 In IP 10.10.10.194.46219 > 10.10.10.1.123: NTPv4, Client, length 48
20:38:23.712171 br-64e46f527ce3 Out IP 10.10.10.194.46219 > 172.19.0.2.123: NTPv4, Client, length 48
20:38:23.712176 veth008b654 Out IP 10.10.10.194.46219 > 172.19.0.2.123: NTPv4, Client, length 48
20:38:23.712229 veth008b654 P IP 172.19.0.2.123 > 10.10.10.194.46219: NTPv4, Server, length 48
20:38:23.712229 br-64e46f527ce3 In IP 172.19.0.2.123 > 10.10.10.194.46219: NTPv4, Server, length 48
20:38:23.712244 enp4s0 Out IP 10.10.10.1.123 > 10.10.10.194.46219: NTPv4, Server, length 48
20:38:56.632992 enp4s0 In IP 10.10.10.23.59208 > 10.10.10.1.123: NTPv4, Client, length 48
20:38:56.633032 br-64e46f527ce3 Out IP 10.10.10.23.59208 > 172.19.0.2.123: NTPv4, Client, length 48
20:38:56.633038 veth008b654 Out IP 10.10.10.23.59208 > 172.19.0.2.123: NTPv4, Client, length 48
20:38:56.633140 veth008b654 P IP 172.19.0.2.123 > 10.10.10.23.59208: NTPv4, Server, length 48
20:38:56.633140 br-64e46f527ce3 In IP 172.19.0.2.123 > 10.10.10.23.59208: NTPv4, Server, length 48
20:38:56.633164 enp4s0 Out IP 10.10.10.1.123 > 10.10.10.23.59208: NTPv4, Server, length 48
20:38:56.633721 enp4s0 In IP 10.10.10.23.46754 > 10.10.10.1.123: NTPv4, Client, length 48
20:38:56.633734 br-64e46f527ce3 Out IP 10.10.10.23.46754 > 172.19.0.2.123: NTPv4, Client, length 48
20:38:56.633737 veth008b654 Out IP 10.10.10.23.46754 > 172.19.0.2.123: NTPv4, Client, length 48
20:38:56.633780 veth008b654 P IP 172.19.0.2.123 > 10.10.10.23.46754: NTPv4, Server, length 48
20:38:56.633780 br-64e46f527ce3 In IP 172.19.0.2.123 > 10.10.10.23.46754: NTPv4, Server, length 48
20:38:56.633794 enp4s0 Out IP 10.10.10.1.123 > 10.10.10.23.46754: NTPv4, Server, length 48
20:38:56.634276 enp4s0 In IP 10.10.10.23.55269 > 10.10.10.1.123: NTPv4, Client, length 48
20:38:56.634289 br-64e46f527ce3 Out IP 10.10.10.23.55269 > 172.19.0.2.123: NTPv4, Client, length 48
20:38:56.634291 veth008b654 Out IP 10.10.10.23.55269 > 172.19.0.2.123: NTPv4, Client, length 48
20:38:56.634337 veth008b654 P IP 172.19.0.2.123 > 10.10.10.23.55269: NTPv4, Server, length 48
20:38:56.634337 br-64e46f527ce3 In IP 172.19.0.2.123 > 10.10.10.23.55269: NTPv4, Server, length 48
20:38:56.634352 enp4s0 Out IP 10.10.10.1.123 > 10.10.10.23.55269: NTPv4, Server, length 48
