Time keeps moving 1 hour ahead
sdiamond808
Joined
Jul 2, 2017
Messages
116
Reaction score
14
8 channel hikvision nvr with 5 hikvision and 3 dahua cams.
Nvr time is correct and constant, however, each camera moves ahead 1 hour a few min after adjustment.
I have synced to PC, manually set, tagged to ntp, even moved time zone that is 1 hour behind. They all fix it for a few min then go ahead an hour. How do you fix this?
wittaj
Joined
Apr 28, 2019
Messages
25,378
Reaction score
49,430
Location
USA
Many of us have noticed that some cams are somehow programmed strange regarding time zones - some may be UTC and others GMT.
You simply need to find a new time zone one hour off of the timezone you are in and change it to that time zone so that it then displays the correct time.
I have a few cameras that I have to do that with as well. But once set, I haven't had to touch them.
sdiamond808
Joined
Jul 2, 2017
Messages
116
Reaction score
14
I'm in central time so I switched to mountain and same result. Worked for a few then went an hour ahead
sdiamond808
Joined
Jul 2, 2017
Messages
116
Reaction score
14
I think it's the dst. Once I unchecked daylight savings it seems to have fixed. If I'm pegged to ntp do I even need dst or will it sync with the server?
wittaj
Joined
Apr 28, 2019
Messages
25,378
Reaction score
49,430
Location
USA
It can certainly be the dst as well. Maybe the camera already has DST programmed into, so checking it is doing it twice.
sdiamond808
Joined
Jul 2, 2017
Messages
116
Reaction score
14
I'll keep it unchecked and ntp option. Hopefully ntp updates it automatically
Mike A.
Joined
May 6, 2017
Messages
3,844
Reaction score
6,424
Generally you do need to do DST adjustments in the cam (or other device) when using NTP. The NTP server passes the time as UTC. The client makes whatever local offsets from that based on its settings.
sdiamond808
Joined
Jul 2, 2017
Messages
116
Reaction score
14
I'll try it out. These things have a mind of their own. I set to ntp come back an hour later and the setting isn't checked anymore even though I've saved it
naamang
Joined
Apr 24, 2024
Messages
19
Reaction score
1
Location
South Bend, IN USA
Sorry to revive an old thread but I'm having the same exact problem and none of these suggestions have helped. The camera will readjust any setting, including DST selection and time zone selection. I lie to it and select (UTC-06:00) Central Time (US & Canada) with DST unchecked and it will change it back to (UTC-05:00) with DST checked and then forwards the time one hour. And it doesn't even get the area correct. Instead of the (UTC-05:00) Indiana East (where I live) or (UTC-05:00) Eastern Time (US & Canada), it changes it to (UTC-05:00) Bogota, Lima, Quito, Rio Branco. Has anyone in this thread figured this out yet? I have two NVRs, one Dahua and one Hikvision. The Dahua is set to not sync time with the cameras and I'm not finding a feature on the HIkvision for time syncing to the cameras so I must assume it's not. NPT is unchecked on all the Dahua cameras also so it should be running only on it's internal clock with no influence from external sources yet it keep switching back to -05:00 and forwarding an hour off,
SpoonZA
Joined
May 14, 2024
Messages
1
Reaction score
Location
Jhb
Naamang, sitting with same issue, HikVision Camera changes settings by itself. I will unchekc DST, and set it to manual sync. Few days later, DST is enabled again by itself. Really frustrating to the point of taking it back to Hikvision for a refund.
Teken
Joined
Aug 11, 2020
Messages
1,616
Reaction score
2,921
Location
Canada
State what the model and firmware is on this specific Hikvision camera.
  • Default the camera to a OEM state.
  • DST: Define the values and when DST should happen.
  • NTP: For now use whatever the camera has assigned for the NTP Server.
  • Reboot the camera and monitor how it behaves. If the time is fine after seven days change the NTP server to whatever you want (internal / external) source.
Report back what you see and observe.
Joined
Jul 31, 2017
Messages
8
Reaction score
2
Try updating firmware for your cameras, check for conflicts between NVR and camera settings, and contact Hikvision/Dahua support for specific help.
naamang
Joined
Apr 24, 2024
Messages
19
Reaction score
1
Location
South Bend, IN USA
It's only happening with Dahua cameras in my case. All my Hikvision cameras are good. Some of the Dahua cameras will change to -4:00 and others will stay at the correct -5:00 but they all forward an hour and they all uncheck the NTP box by themselves. I've just given up on them to maintain my sanity.
Flintstone61
Joined
Feb 4, 2020
Messages
6,687
Reaction score
11,077
Location
Minnesota USA
I think if the camera has been installed to an NVR, the NVR is the admin of Time. the cams are slaves. if you try and make the cameras smart with their own NTP's and DST's and such, The NVR/Admin slaps them back to whatever timekeeping it's using for sync.
one thing to think about trying is reset the cams to factory defaults and reinstall to NVR and let the NVr do the Timekeeping duties.
Flintstone61
Joined
Feb 4, 2020
Messages
6,687
Reaction score
11,077
Location
Minnesota USA
the other thing you can do, is run the cameras from a POE switch, thus freeing them the NVR'S internal 10.x.x.x network and the Cams/slaves are free to run thier own NTP settings and DST settings.
naamang
Joined
Apr 24, 2024
Messages
19
Reaction score
1
Location
South Bend, IN USA
All my cameras are already on a 32-port POE switch, and the NVRs are configured to not sync with cameras. They are now out of sync with each other by several seconds but still one hour ahead. I had the same issue when the NVR was master time sync.
Teken
Joined
Aug 11, 2020
Messages
1,616
Reaction score
2,921
Location
Canada
Have you followed all the steps outlined up above by me?!?
Top
