Thoughts in this PC?
rmanTX
Nov 12, 2017
100
8
Hey y'all,
I know there's a guide/sticky for this, but I'm not exactly the most technologically advanced guy.
My current PC is a i5, about 4 years old. I think 4gb of ram, honestly not sure. Running both my HTPC and BI w/ 6 cams, typically see 45% cpu usage.
New PC is i7 7700 7th gen, 8gb ram. Still plan to run my HTPC off it. My buddy swears by Milestone.
So question 1 is, is this PC sufficient?
Question 2 is, is Milestone that much better than BI?
Sent from my SM-N960U using Tapatalk
Try Milestone...you'll come running back... what i5? What cams?...if the i5 worked the i7 will be fine.fyi that i7 is last gen so hopefully you didn't overpay..
I don't even know what i5. It's old haha.
I'm using the Chiness Dahua IPC-HDW4631C cams. They work great for me and I got 8 or 9 on ebay for $55-65 (a few here and there)
The i7 was a gift. I wasn't expecting it to come with a 8gb stick or a 240gb ssd, so I'm happy.
