The Importance of Focal Length over MP in camera selection
And a recognition that DORI numbers are ideal, best case scenario with ideal light and no movement.
Most here will cut that number in half during the day, and cut that half number in at least half at night.
Need a tablet next to our cameras that would flash a beautiful woman, when tripped, so the intruders would stare at the camera so we would get a good clear focused pic LOL
Which brings me to Height of CAMs. Best placement would be eye level, too high and all you get is the top of their heads...one reason Doorbell CAMs get good shots, everyone does look directly at the Doorbell when they push the button and you get to see if they have anything in their nose too :lol:
For reference, here are my front door 5442s. Height is about 9.5'. One is above the front door, the other is about 11' away. They are both 3.6mm. It depends on the person and what they're doing as to whether I can get a good face capture or not.
I also have a 2.8mm next to the door, just above the doorbell. I have considered changing it out for a 3.6mm, but it hasn't been a strong consideration. I do need to work on some settings adjustments though. The seasons really make a difference with lighting and cloud cover.
I also just made this to tell people I am both not interested and to draw more attention to looking over that way.
Probably a little overcooked, but with the right settings, it can make a difference
You got em' coming and going...
Once I finally get back onto this project, and wrap it up, I will have another angle as well.
Here is a great thread putting together in chart form the appropriate sensor size for the MP you are looking at. If the MP/sensor combo is red, then it will perform poorly at night:
Alright - probably a dumb question (and/or one that's been answered ad nauseam and I'm not searching the right keywords): say I have a 8MP cam with a 1/2.8" sensor (Amcrest 2779EW, if relevant) which is clearly in 'red' territory; assuming that just changing its resolution to 1080p doesn't put it in 'green' territory?
Reactions: StevenFromTexas
Downrezing a camera does not work - It is still using the 8 million pixels - the camera doesn't change the "pixel resolution screen" on the camera when you go from 8MP to 4MP. The sensor still needs 2 times the light going from 8MP to 4MP, so the native 4MP camera will result in a better image at night. The firmware will make some algorithm attempt at downrezing it, but it could be a complete crap image or a somewhat usable image, but if there is a concern that the 8MP isn't performing or wouldn't perform well at night, then it is better to go with the 4MP.
I have a 4MP and 2MP on the same 1/2.8" sensor and the picture quality is quite different between the two and the 2MP kicks it's butt at night.
In most instances, you want to get a camera that will perform at your location for the worse situation, which for most of us is at night when it is dark and there is little to no light. If a camera performs at night, it is easier to tweak settings to make it work during the day than it is the other way around.
My 2MP cameras outperform my neighbors 4K (8MP) cameras....why....because they are both on the same size sensor.
When we had a thief come thru here and get into a lot of cars, the police couldn't use one video or photo from anyone's system but mine. Not even my other neighbors $1,300 8MP system provided useful info - the cams just didn't cut it at night.
My neighbor tried the "I will just downrez the 8MP to 2MP" and the image was a soft dark mess.
His system wasn't even a year old and after that event has started replacing with cameras purchased from Andy based on my recommendation and seeing my results. He is still shocked a 2MP camera performs better than his 4k cameras and he cannot figure out why downrezing from 8MP to 2MP doesn't work properly... It is all about the amount of light needed and getting the right camera for the right location and downrezing doesn't change the physics of the camera.
Shine a flashlight through a chain link fence
Now shine that same flashlight through mesh pool screen meant to keep out tiny mosquitos.
Good analogy.
Learning from you guys. Sensor size to MP size will make or break a Camera. Too small of a sensor on an 8MP is no good, especially at night.
Every camera is only as good at the light provided to it...no matter how expensive the camera is.
Incredible to get both a technical explanation and an immediately graspable analogy within ~15 mins of posting this question.
Thank's y'all, this community is rad.
Stick around, I have been here about 3 years and still learning from these guys...
I think the key is knowing the basics. For me, like so many when we first start out, think we only need a few cameras, a dozen cameras later, lol, each camera has a job and there is no one camera that does them all.
Our Cliff Notes is a good read, I learned alot of the basics there. It is a bit long but full of alot of great tips...
So just to make sure I'm getting the basics right, bigger sensor, bigger lens (good quality) are the 'gold standard' if you like, or is there a trade for image quality if the lens is too big?
Reactions: David L
Lens size is normally measured by your FOV (Field of View) 2,8mm is wide, 6mm is narrow. Bigger Sensor means it can handle less light so it is good for night. Too much MP (ex. 8MP) and small Sensor is not good. Same Sensor size a 4MP works better, less pixels to process.
But 8MP with Sunlight (Daylight) will be a better daytime picture than 4MP since it is twice the pixels.
This helps with figuring your FOV needed for the home/location your Camera will be mounted...
HTH
Sometimes we see the bigger sensor and lens combo create a tight area of focus, like the 4K/T that many say outside of 15-25ish feet the focus will be soft/blurry shorter and further than that distance.
Reactions: Rosey14 and David L
Thanks for the replies, I used the wrong terminology, I ment aperture size not lens size. I currently have a 8mp darkfighter bullet camera with 1 1/8 cmos and f 1.6 and the picture at night is not exactly high quality. Its OK. After reading alot on here I realised I was chasing mp's rather than looking for dori ratings, cmos and f stop etc. Now I'm looking at a hikvision 4mp varifocal bullet with 1 1/8 cmos, 1.0 f stop with colour view technology to replace it. Hopefully it will produce better images in low light. Duaha cameras that are spoken very highly about seem to be not that common in the uk, but I would rather go with hikvision as I am running a hikvision nvr and a few other cameras ( which I'm happy with) around my home
Realize that the larger the aperture, the narrower the DOF (Depth Of Field), which is the distance range the picture is in focus. An f 1.0 aperture will have less of an in-focus range than an f 1.6 will. This is no different than photography, like how an SLR or DSLR camera works. This is what @wittaj is talking about in post #136 above.
So you need to define the job of the cam and pick one that fits that criteria. You will never find one that is 100% perfect. Each cam has its pros and cons.
Just modded a cheap camera with 25mm lens after reading this a few days ago
50-60ft from the camera to my neighbour's duck position, the only light source available was a small bulb from the house on the left around 20ft away. The image seems to be more brighter even on low light which surprised me since I was expecting the image to be more darker than the original lens.
Definitely a good cheap substitute if you need something for identification and buy a wide angle one for general monitoring.
IMG_20250820_205901[1].jpgView attachment 1755696866941.mp4
