I definitely don't have the light, but I will see what I can do.I would definitely like to see color at night. You may not have enough light, but I'd still like to see what it looks like. Thanks
Yeah, figured. But just to get a look at what it is in color is all I'm concerned about. Just for comparison sake.I definitely don't have the light, but I will see what I can do.
Don't know why Dahua did not may the Camera Arm a bit Longer so we would not have to do this...I picked up a PFB203 junction box to try and come up with a solution for mounting it to the fence that wasn't the PFA124. I wanted to have better use of the rotation in the arm to get it pointed where I wanted it. I have made some revisions to the spacer and sent the file over to my neighbor. Hopefully he is able to print another in the morning. It's PLA for now, but will be ABS or PETG one I get it finalized.
The new revision includes locator holes that align with the tapped holes already in the junction box. If anyone else requires one of these, they can more easily use the spacer as a template for marking the holes that need to be drilled and tapped for the 4 bolt, bolt pattern on this camera.
Yea, beats me too.Don't know why Dahua did not may the Camera Arm a bit Longer so we would not have to do this...
He could start selling them as an accessory to the CAMYea, beats me too.
I haven't heard back from my neighbor, but hopefully he is able to make a print today.
Anyone know if similar trigger rules for this camera will also work with the EmpireTech NVR8CH-8P-2AI NVR?IVS ONVIF triggers only come from the Near (Panoramic) channel, so a trigger rule will need to be set up in BI to trigger the Mid and Far channels if you want them to switch from Sub to Main (I plan to do this by triggering a group). IVS triggers can be set across the 3 FOV, but they all live on the Near channel.
Hopefully a future firmware will fix that.Someone already figured out how to force the camera into black and white ?
Unfortunately the camera has no settings for this in menu like any other dahua camera since decades.
Its still possible to switch the profile via api, but its useless if the Color/BW stays in automode
As always with all dahua cameras, if you use manual shutter settings, the automode fails.
hard to post any good night shots
I am not completely following what issues you are having. My Day/Night Switch is working, and not being controlled with an API.Someone already figured out how to force the camera into black and white ?
Unfortunately I just installed Windows 11 and don't have IE on this PC. I typically remote in to my BI PC and load through IE on there, but was being lazy.What I found on my Thermal is you Have to use IE, not Edge. @wittaj helped me with that...without IE I found several features did not work or show up.
The behavior in IE was similar, but with some jiggling of the handle by going back and forth between profiles, it switched to a forced B/W.
So Windows 11, which is what I use, apparently has IE but I had to make the file @wittaj suggested and it worked great. It was a plugin the camera web interface kept asking for.Unfortunately I just installed Windows 11 and don't have IE on this PC. I typically remote in to my BI PC and load through IE on there, but was being lazy.
Auto, B/W, and Color is controlled on the Distant View settings. I mentioned this in my first post. Each channel is also independently controlled when it comes to Working Mode, make sure they are all set the same.
I did notice when attempting to force to B/W, that it did not change.
