fenderman
Staff member
- Mar 9, 2014
- 36,883
- 21,419
It might be using seconds rather than frames..The Sunba 507 only allows iFrame selection from 2 to 12. No other choices are available. At least that is what I see on my camera.
Sorry for not responding sooner, but I never noticed that you had asked a question. I really don't know if the camera will work installed upside down. You should send a message to Sunba in their Ebay store, as they seem to be responsive to questions posed there. There is a image "flip" setting in the Camera Parameters settings that does work. It will flip the image upside down. But I don't know if the camera will be damaged if installed upside down. Also, the Sunba 6 inch black face dome model does have upward tilt, so you might want to consider that model instead. Good luck.
Has anyone been able to get the Sunba 507-20XB to UNDEREXPOSE at night (turn gain way down)? I have to do that to see details on cars past the headlight glare. None of the camera's setup exposure controls in the IE plugin seem to have any effect on the image at night, although they do function during the day. I got the camera to monitor a road 300' away (full zoom). The IR leds are plenty bright, but the camera seems stuck in high-gain mode, and the kind of image I'm getting at night (see below) is just not useful. I just assumed I'd be able to turn down the gain since all my other cameras allow me to do that, but is it really not possible on this one? To make matters worse the always-on autofocus then tries to adjust for the big light blobs from the taillights, which throws everything off.
I am having same problem with night time picture so far Im keeping it on color mode at night because I have enough light from a street light but its not close to what the daylight picture is so I will be tinkering with settings any new info as of 5/25/2017, By the way my 7 reolink c2 cameras at $99 each blow this sunba 507 away day or night but it only has 3x optical zoomLED Mode and IR Cut filter:
The LEDs on the Sunba are so bright that I was having trouble from insects, mist, and dust either triggering the camera or blotting out the image. so I decided to use external illuminators at some distance from the camera. To turn off the camera LEDs, I tried (in the OSD) adjusting the LED-on photo resistor levels and tried putting the camera LED mode in off to no avail. In my rural neck of the woods the photo resistor always reads 255 once it gets dark out. When I put it in off mode it kept switching back to auto mode.
I was informed by Sunba that this is the way it's designed. So turning the LEDs off in the OSD only keeps them off until it gets dark, then it goes back to auto mode. So now I am temporarily just covering my LEDs with electrical tape.
Regarding the IR cut filter I asked four times for an explanation of what exactly 'automatically switch' meant in the camera settings. I finally received this answer:
"In the IR cut filter settings, IR synchronous means that the status of IR cut will adjust itself according to the IR LED. When IR LED is on, the IR cut will also be on; same as when IR LED is off.
While IR automatic means the IR cut will be forced in response to the lights condition around."
Does that mean it has its own built-in photoresistor setting? I declined to pursue it any further, I got the impression that nobody there really knew.
The next time I take the camera down, I'll open the body and remove the wire harnesses to the LEDs.
I don't have my indirect lighting fully worked out, but so far it's definitely improved the image and reduced false triggers.
Sunba posted a new firmware to address the IR over exposure on Nov 21st.
