- Sep 14, 2015
- 1,248
- 4,175
@ ssatyer, i did set some presets in the camera when i had it connected to the lan and connecting to the camera with the CMS that comes with it.
But from the dahua i can't seem to call the presets that i have set?!?
https://www.dropbox.com/s/1qttf8a6fcng0g5/20160204065958.mp4?dl=0
Quality is not great since it is substream and made by phone but you see whats going on.
@Lulu,
Thats the same thing i thought off.
I already do this with a timer that turns the power off for the accespoint that i have setup as receiver to feed the recorder.
This powers the device of for a few seconds at night , otherwise the connection will fail after a while.
Not sure where the problem is at this point, wifi from the neighbors or the AP im using, or combination of both.
But this will be hopefully solved by tomorrow since i am going to install for them 3 ubiquity unifi AP's
Will make my signal better as well
So for now, its is ok again but i do not hope this is the beginning of something bad :sad2:
When I first got this camera I thought to myself, that it seems very well built and heavy for it's size. The only thing that I thought was cheap was the power adapter. It seemed pretty light weight and if ever start having problems with my camera that will be one of the first things I check.
