sebastiantombs
You do need to enter the correct IP and login credentials to use find/inspect or configure the camera if they're not already there.
Maybe try deleting and readding the cameraI guess for now I will use "/cam/realmonitor?channel=1&subtype=1&unicast=true" since the inspect won't give me the correct information.
Thanks for your help.
For BI to detect the substream properly you need to have onvif enabled in the camera.I've had a similar problem in BI with a Hikvision DS-2CD2035FWD-I 3 Mp bullet camera, the substream isn't showing up when I use Find/Inspect. I have 2 similar Hikvision anti-vandal domes in the same G1 series and here have had no problem getting the substreams to show.
I notice in Find/Inspect with the bullet it seems to be looking for profiles but no profiles are being recognized, but are with the domes.
I have this now working for the bullet, giving me Main and Sub streams for BI to display and use.
Make Generic/Onvif
Model *RTSP H.264/H.265/MJPG?MPEG4
Stream profiles are both on default, Find/Inspect doesn't offer anything in a drop down menu so I had to manually enter the stream details.
For Main I entered, /Streaming/Channels/101?transportmode=unicast
For Sub I entered, /Streaming/Channels/102?transportmode=unicast
On the domes here Find/Inspect did work properly and delivered these Stream profiles -
mainprofile: /Streaming/Channels/101?transportmode=unicast&profile=Profile_1
substream: /Streaming/Channels/102?transportmode=unicast&profile=Profile_2
Just a guess but it seems that Find/Inspect is looking for Profiles from the camera and not getting an answer. With the bullet camera, without me entering the streams details, Main is on default, Sub is none, no stream details appear, the two boxes are blank, only the main stream is displayed and available to BI. This is a similar situation to what the OP has posted.
Is there some setting on the camera's configuration concerning profiles that needs adjusting, using say the Hikvision web browser tool?
