So I just tried:
Main Stream: /cam/realmonitor?channel=1&subtype=0
1st Sub Stream: /cam/realmonitor?channel=1&subtype=1
This is right from the Sub Stream Guide. So far it seemed to work. General Tab of the Camera settings are now showing Sub Stream activity.
Should I keep this or change it to your recommendation?
I had to do the same with a Loryta 3.6MM I purchased from EmpireTech on Amazon (Feb 5th). I didn't notice the substream wasn't working until the other day and then found this thread.
The above solution worked... thank you very much!
I have two of these Loryta 3.6MM cameras one purchased on Nov 20 21 and the other on Feb 05 22.
The camera purchased on Feb 05 22 has a firmware version V2 800.15OG001.0.R Build Date: 2020-10-14 <----- Had to use the above solution to get substream working
The other camera that was purchased earlier on Nov 20 21 has V2. 820.15OG000.0.R Build Date:2021-05-08 <---- No problem with substream
The camera that has the V2.820... firmware auto-populates with the following settings.
/cam/realmonitor?channel=1&subtype=0&unicast=true&proto=Onvif
/cam/realmonitor?channel=1&subtype=1&unicast=true&proto=Onvif
Not sure if I should flash the newer firmware or don't fix what seems to be working with the above fix. Andy must have gotten some old stock back in Feb 2022
Thanks for the support, I have learned so much from you guys.
Cheers!
