Hi all
I am looking for new cameras to replace my 15 years old vivotek system, which is close to useless in terms of image quality.
A friend of mine suggested me the brand Annke, as it is a budget oriented hikvision spinoff. I was close to ordering 4 C800 turret cameras (I9DM) paired with a NR168 NVR (I need the NVR to be 16ch, since I already have 4 indoor ezviz cameras which I want to feed into it). The total price comes close to 540 euros, including a 4tb HDD.
However, as I was lurking on this forum, I realized that the sensor is tiny (1/2,5") and in low light the image will be utterly terrible. As I'm mostly interested in low light conditions, this is unacceptable.
I am wondering if there are other options (any brand) which will guarantee a better night image clarity, while still not breaking the bank. The dual light (IR+white) option seemed compelling, but I read that the white light isn't just bright enough to see people at night. Maybe it would be beneficial to mount a separate led outdoor light close to the cameras (triggered by PIR) to illuminate the scene?
My total budget is around 600 euros.
Thank you very much for your help!!
