Strobe Light on and off
NoProblems
May 10, 2021
38
16
United States
I've never had to add an external device like this strobe light to an IP camera before so i need your guidance Based on the IPC-B54IR-Z4E-S3 specs, it has a 1 channel out: wet contact, 300mA 12V DC, which I think means it can control a device like a strobe light, as long as the strobe is 12V DC and draws less than 300mA. Is that correct ? If that does not work i guess i could add one of these Relay
I know the camera has ALARM_OUT, which outputs a signal to the alarm device, and ALARM_OUT_GND for ground. Since the wires are quite small, what type of terminal or connector do you use to connect them to external wiring?
