There is no way it could work in the way you described...how would the camera know your wifi settings...it will be under user management or system settings
Please give me the model number so i can lookup the manual or some info on where it is in the camera settings..
Alternatively if you want we can do a remote session via teamviewer...
Click on user management or system settings and find an option for wireless lan settings.
(as an aside, these cameras, even when working properly are junk, there are much better options out there, the image quality on this will be poor).
1) Use P2P finder to find your ipcamera IP.
2) Add ipcamera to DeviceViewer adding IP and PORT! By default lan port is 81 and not 8080.
3) Right-click on the camera listed in DiviceViewer and choose "device param"
4) Use Wifi tab (IF IT WORKS) to setup your wifi connection.
3) Right-click on the camera listed in DiviceViewer and choose "device param"???????![]()
