Solar Wireless Bridge 2 camera recommendations
ron351
Jul 24, 2017
124
51
Looking for someone who can suggest a solar panel setup that will power a wireless bridge antenna to a POE switch and 2 possibly 3 4K POE cameras that won't run out of power overnight.
Nothing very expensive like we see in some parking lots at large stores or setups like some police use.
I could also eliminate the POE switch and come off the 12v to the 12v pigtail on the cameras if better.
This is going to be in a large cemetery and can not run buried wire there due to graves so looking for some system that someone has setup and tried that will work.
Thank you in advance for any input that will guide me to a decision.
Ron
I must be the only one to attempt to install one of these solar systems.
I am contacting this company for guidance as their system seems straight forward.
It’s expensive. Expect to spend a several grand on the buildout. That much power draw 24/7 will require large panels and batteries.
